Randall Raymond
November 18, 2007 at 10:19 pm[Aharon Rabinowitz] “[Raymond Motion Pictures] “320×240 – 30fps – start with 400bps – the flv file should then be served up as is.”
Where did you hear this? 400Bps is Extremely low. maybe you mean Kbps?”
Yes. If they are using Flash 7 – it looks to me to be encoded at about 200kbps. In your testing, did you ever try an extremely high rate Flash 7 encode at, say, 1500kbps for upload?
Aharon Rabinowitz
November 18, 2007 at 11:41 pm[Raymond Motion Pictures] “In your testing, did you ever try an extremely high rate Flash 7 encode at, say, 1500kbps for upload?”
yes, and you can see those here:
https://youtube.com/watch?v=PrUftJgPcUo
https://youtube.com/watch?v=9YJZ1tYUytY
https://youtube.com/watch?v=txoSMiduObY
However, shortly after doing these tests, YouTube stopped allowing users to upload FLV’s without their re-encoding it. It is not possible. No matter what you upload, they re-encode it.
Aharon Rabinowitz
Email: arabinowitz (AT) yahoo (DOT) com
All Bets Are Off Productions, Inc.
Creative Cow After Effect Podcast
Internet Killed the Video Star: A Guide to Creating Video for the Web -
Randall Raymond
November 19, 2007 at 12:53 am[Aharon Rabinowitz] “However, shortly after doing these tests, YouTube stopped allowing users to upload FLV’s without their re-encoding it. It is not possible. No matter what you upload, they re-encode it.”
That’s unfortunate and really stupid of them. YouTube gives me a headache after watching a few in a row. Obviously, bandwidth usage has become a problem for them.
Christopher Smith
November 22, 2007 at 4:34 pmI just uploaded to You Tube (https://www.youtube.com/watch?v=7jJ95QbPaHE) video shot with XH-A1 at HD combined with DV. Compiled using Vegas 8 – 640 x 480 (as per new You Tube specs) – .mov – using “Good” setting – mono (as per You Tube specs). It was a little over 5 minutes and came in at 93Mb (must be under 10 minutes and 100Mb per You Tube). You can look at my footage and judge by that if it is acceptable. Hope this helps.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Magee
November 24, 2007 at 1:10 amThanks for that,
the Tori Amos video looks good
Can you tell me what settings you used in the .mov render? I see there are a huge number of options. -
Christopher Smith
November 24, 2007 at 3:42 amThanks for the compliment John. I used .mov at 640×480 at “good” setting. My sound was at mono and the video was set to MPEG-4. If you go to “My account” you can click on a help area and they have the suggested settings for uploads. They use to be at 320 x 240 but for some reason changed to the 640 x 480. I think if I had size problems that is the first setting I would change. I was too large using the “best” setting but going to “good” fixed the problem. Hope that helps.
John Magee
November 24, 2007 at 10:08 pmThanks Christopher,
when I go to the “render as” (Vpro8)I see quicktime(.mov). I then have choice of templates – uncompressed, 3mbs, etc. After picking one of those there are more format questions – target bit rates, mp4 or Sorenson or…and then audio – more formats there – the default one is one that sounds really bad – are we looking at the same thing here?
John -
Christopher Smith
November 25, 2007 at 2:09 amJohn,
After you choose the .mov format, click on the “custom” button on the right and make the further choices from there. Once you choose the ones I mentioned earlier you can name the template yourself as “You tube” and save it. The next time you go in those custom settings will be available as a template. Hope this helped.Chris
