Activity › Forums › Avid Media Composer › Remove motion effect and ripple sequence
Glenn Sakatch replied 13 years, 5 months ago 5 Members · 11 Replies
Glenn Sakatch
April 4, 2013 at 7:52 pmIf you have not changed the in/out points on a clip since it was used to create the motion effect clip, alt matchframe will call up the clip without affecting its in/outpoints. Without alt you will simply get a new inpoint at your matched frame. Then the trick of using locators would be a good work around.
Glenn
