Activity Forums DaVinci Resolve Remote Grading for a newbie
  • Ola Haldor voll
    September 25, 2011 at 8:15 pm
    OK, so.. A little question here. Let’s say I’ve graded on my own and I want to present this to the client. I have all the grading done on my end, while on the client end nothing has been graded. What will happen when I connect?
    Or would it just be easier to export/import project?
  • Jake Blackstone
    September 25, 2011 at 10:45 pm
    Yes, you can export it, but even easier, once you connect the slave Resolve will download graded session from the master and you’re ready with your presentation, as well as being able to render it. If you’re working with Alexa material just make sure your LUTs are sorted out. LUTs don’t get downloaded, like they do with project export, unless you used it with one of your nodes. But then you need to make sure the name of the LUT is the same on both machines.
Page 2 of 2
