Activity › Forums › Apple Final Cut Pro Legacy › Relinking Nightmare
  • Arnie Schlissel
    May 21, 2010 at 6:39 pm
    [Scott Davis] “So if I had not of selected “delete unused media” then it would have copied over the entire clip and linked all instances of it to the one clip?”
    That’s right.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Rainer Wirth
    May 21, 2010 at 7:17 pm
    yeap,
    that was the problem. Never do it again, because HD are so cheap that is isn’t worth the whole mess.
    Sorry
    Rainer
  • Michael Gissing
    May 22, 2010 at 1:08 am
    The way you did it, meant that Media Manager worked properly, just a misunderstanding of the mode. It is always a good idea to experiment with small projects to understand how Media Manager works. The manual is only helpful to a certain extent. The terminology is poor. Most people freak at the option “delete unused media” It really should say “Consolidate Media” or “Don’t include unused media”.
    Why not transfer the media back off the other system using Media Manager to Copy the sequence to an external.This time just do a straight copy without using “delete unused media” unless you want to further consolidate.
    Drives are so cheap that this will be quicker (and therefore cheaper) than thousands of manual relinks or recapture off tape.
Page 2 of 2
