Ty Ford
April 1, 2011 at 11:59 am+1, Will.
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field GuideWatch Ty play guitar -
Brian Reynolds
April 1, 2011 at 10:38 pmI have recently charged the DSLR guys “travel time + hourly rate” it comes out to be about 3hrs = 1/2 day $ rate.
A bit like a plumber does….by the hour.
What it has done is it makes the tallent and producer better rehearsed and prepared with far fewer takes. Yes you work less hours but overall but the $ aren’t that much less, your still in the production loop and the sound quality is still good.
It also stops the need for them hiring the gear and doing it themselves with poor results.Over the years equipment has changed to suit the work-flow why shouldn’t crew structures as well?
The difference between Knowledge and Wisdom is… Knowledge is the knowing of facts…. Wisdom is the sensible application of good quality knowledge…
