Activity › Forums › Avid Media Composer › Re-link issue: Avid can’t see drive
Peter Humble replied 12 years, 5 months ago 5 Members · 21 Replies
Pat Horridge
March 13, 2014 at 2:33 pmTaking it this is on a Mac.
Make sure at the root of the drive when you get info you have ownership and permissions turned off. That will leave the drive free of permission issues.Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US -
Peter Humble
March 14, 2014 at 12:15 amThanks Pat, yes I am on a Mac.
[Pat Horridge] “Make sure at the root of the drive when you get info you have ownership and permissions turned off.”
So how do I do that? There’s no option to turn permissions off. When I ‘get info’ I can only select ‘Read/Write’ or ‘Read only’
Peter
John Pale
March 14, 2014 at 2:56 am -
Peter Humble
March 14, 2014 at 4:56 amOh I see. Mine was locked, hence greyed out.
Will try.Many thanks
Pat Horridge
March 14, 2014 at 6:18 amIts the ignore ownership tick.
Pat Horridge
VET
John Pale
March 14, 2014 at 12:29 pm“Oh I see. Mine was locked, hence greyed out.
Will try.”It’s locked by default. Click the lock and it will ask for your Admin password, then you can change it.
Peter Humble
March 25, 2014 at 11:53 pmHi,
Just got around to trying this.
Unfortunately this solution hasn’t worked.I still can’t direct imported files to my external drive as AVID can’t see it. (All permissions are now ‘ignored’)
The weird thing is when I click Import I can navigate to the files on my drive but I just can’t choose to put the MXF files in the same location.
This is a massive limitation.
Any other suggestions? -
Michael Hancock
March 26, 2014 at 12:23 amOpen the console in Avid (Cmd/Ctrl+6). Type “alldrives” without the quotation marks. Hit Enter. It should say something along the lines of “all drives now acting as media drives.” You might need to restart Avid, but try to import something and see if you can select the external drive now.
Michael Hancock
Editor -
Peter Humble
March 26, 2014 at 3:50 amThanks, I was excited to try this I was sure it would work but no luck unfortunately. It didn’t work?
Anything else I can try?
Pat Horridge
March 26, 2014 at 10:52 amAt this stage I’d test with a second external drive.
This is an OS or drive related issue for sure.It is an HFS+ drive I assume (not FAT32 or NTFS?)
You could try re-formatting the drive and re-testing but easier to test on a second drive first.
I regularly get permission issues that are hard to fix. It seems the Apple GUI that allows you control of the drive permissions sit’s on top of the underlying UNIX permission and I’ve had them go out of sync. The result is the Apple GUI shows permissions that the underling UNIX doesn’t. Permission fixing often doesn’t help. A reformat does.
Also have you tried deleting the Avid MediaFiles folder on that external drive. Then re try capturing to it.
Pat Horridge
VET
