Activity Forums Adobe After Effects Expressions Random Wiggle Opacity from 100% to 0%
  • Random Wiggle Opacity from 100% to 0%
    Posted by Kuba Lu on June 19, 2013 at 5:02 pm
    Hi guys,
    I have a picture of a night cityscape with loads of buildings. I basically need to switch of all the lights in the city. The scene is 12 seconds long and the lights need to go off randomly throughout the whole city. I masked all the windows (and there are hundreds and hundreds of them) and I’m trying to figure out how to do the job without doing it manually.
    Does any of you know an expression that would randomly change the Mask Opacity from 100% to 0%?
    I found few expressions that make the layers blink but I couldn’t find any that would knock down the opacity to 0 and make it stay there.
    Kuba
    Dan Ebberts replied 4 years, 2 months ago 5 Members · 14 Replies
  • 14 Replies
  • Dan Ebberts
    June 19, 2013 at 5:14 pm
    Something like this should work:
    wiggle(1,100) < 100 ? 0 : 100
    Dan
  • Kuba Lu
    June 19, 2013 at 5:18 pm
    It still makes it flicker
    hmm…
  • Dan Ebberts
    June 19, 2013 at 5:23 pm
    sorry, I misunderstood. Try this one:
    seedRandom(index,true);
    if (time > random(thisComp.duration)) 0 else 100
    Dan
  • Kuba Lu
    June 19, 2013 at 5:30 pm
    Jeez !!!
    That works. Thanks so much Dan!
    Do you know if it’s possible to change the opacity across 4 frames so it fades out ?
    Cheers !
    Kuba
  • Dan Ebberts
    June 19, 2013 at 5:37 pm
    This should work:
    t = random(thisComp.duration);
    ease(time,t,t+thisComp.frameDuration*4,100,0)
    Dan
  • Kuba Lu
    June 20, 2013 at 9:21 am
    You’re a genius !
  • Reynoud Van der molen
    February 26, 2018 at 5:10 pm
    Hi Dan,
    I saw the incredible handy expression you created for Kuba, and I used for a similair project with a skyline and a bunch of layers.
    Now the project is evolving and I was wondering, since I am fairly new to expressions in AE, is there a easy add to let the opacity wiggle between 100% and 0% at multiple random moments.
    So to more clear: it would not just turn on or off once, but sometimes it would turn on and some times it would turn on, randomly. Or if it is easier with an predetermined frequency I can alter?
    Kind Regards,
    Reynoud
    Studio NOUD
  • Pierrick Allan
    September 29, 2019 at 7:30 am
    Hello, and thank you for the amazing help.
    the expression “wiggle(1,100) < 100 ? 0 : 100” is what i was looking for, but it’s a bit brutal. How can I add smoothing to it? For it to change from 0 to 100 and vice versa but with 4 frames of transition?
    I’ve tried to add something like seedRandom(time*5); but it doesn’t work
    Thank you so much for your help,
    Best,
    Pierrick
  • Dan Ebberts
    September 29, 2019 at 4:48 pm
    Try this:
    fadeTime = framesToTime(4);
    curState = wiggle(1,100) < 100;
    t = thisComp.frameDuration
    while (curState == wiggle(1,100,1,0.5,time-t) < 100){
    t += thisComp.frameDuration;
    tt = time -t;
    if (curState){
    linear(time,tt,tt+fadeTime,100,0);
    }else{
    linear(time,tt,tt+fadeTime,0,100);
    Dan
  • Pierrick Allan
    October 1, 2019 at 8:14 am
    Thank you Dan ! This worked perfectly and I was able to finish my project on time !
    For the others who might want to avoid expressions, i found out that you can do the same with the effect “Strobe Light”
