Activity › Forums › Apple Final Cut Pro Legacy › Random clicking sound
John Fishback
November 26, 2014 at 4:34 amSlight differences in noise levels between 2 clips can cause a click at edit points. If you apply a 2 to 4 frame audio fade the click will go away. Some DAWs force an edit at “zero crossing” points. That’s the point in the file where the audio waveform crosses zero. Edit there and no click. I don’t know of any NLE that does that automatically. But, applying a fade smooths the transitional gain so no click.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.9.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCP-X 10.1.3, Motion 5.0.7, Compressor 4.0.7
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Hans Douma
March 27, 2015 at 3:56 pmHi,
It’s been a long time since you posted this issue and the reason I am reacting on it now is I am having the same problem in FCPX 10.1.4 as you did. My original footage is MTS and the audio sounds fine. It is only after importing it into FCPX random clicks occur. When I import the same footage into iMovie there is no problem. So the issue is definitively in FCPX>
I wonder, did you ever find a solution for it ?
