Activity › Forums › Apple Final Cut Pro Legacy › RAID External Solutions
  • Pierre-luc Pare
    March 30, 2007 at 7:49 pm
    Oh damn, you mean you don’t have to connect any cables to the drives, it’s kind of built-in plugged ? Very bad, very bad Apple, would be so easy to do into a PC. Ok well, I’ll keep looking for external RAID. Do you have other suggestions apart of the very nice looking 3ware ?
    Thanks a lot !
  • Pierre-luc Pare
    March 30, 2007 at 8:12 pm
    The CalDigit S2VR HD seems to be exactly what I need, for 2K$.
  • Jeremy Garchow
    March 30, 2007 at 8:22 pm
    [Pierre-Luc] “The CalDigit S2VR HD seems to be exactly what I need, for 2K$.”
    Again, Raid 0
  • Pierre-luc Pare
    March 30, 2007 at 8:33 pm
    I see, where come from the “Protected” feature they offer ?
    Really not easy to find what I need…
  • Jack Fox
    March 30, 2007 at 8:34 pm
    What about G-Speed fibre channel with a PCI-X card?
    jmf
  • Walter Biscardi
    March 30, 2007 at 8:39 pm
    [Pierre-Luc] ”
    We killed two of them here in about 3 months time so we’re looking elsewhere right now. Just FYI.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Walter Biscardi
    March 30, 2007 at 8:41 pm
    [Pierre-Luc] ”
    Really not easy to find what I need…”
    Sure it’s easy to find it, but not cheaply. Fibre Channel gives you all the flexibility you need.
    If you’re going to run SATA or anything at RAID 0, just be sure to run a backup unit at ALL times. When the CalDigit’s went sour on us, we had everything backed up on a LaCie 2TB FW800 unit that let us keep working. Without that, we were screwed.
  • Shane Ross
    Protected is RAID 1, meaning if you have four 500GB drives in there, you only get 1TB of storage. The drives are mirrored, so two sets of 500GB raided drives. And the drive performance isn’t as fast. Fast enough for DVCPRO HD and uncompressed SD setups, but not for Uncompressed HD.
    Raid 5 is a tough thing to find…cheaply.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Walter Biscardi
    March 30, 2007 at 8:45 pm
    [Shane Ross] ”
    Raid 5 is a tough thing to find…cheaply.”
    yep, don’t think it’s available anywhere but Fibre Channel right now. Of course all this could go out the window in a few weeks in Vegas.
  • Shane Ross
    March 30, 2007 at 8:48 pm
    [walter biscardi] “yep, don’t think it’s available anywhere but Fibre Channel right now.”
    Well, as I pointed out, Sidecar has a SATA solution:
    https://www.3ware.com/products/Ext_serial_ata2-9000.asp
    Shane
    Littlefrog Post
    http://www.lfhd.net
Page 3 of 5
