Activity › Forums › Panasonic Cameras › Quantify the difference between DVCProHD and H.264
Toke replied 20 years, 5 months ago 7 Members · 13 Replies
Toke
April 25, 2006 at 11:16 pmAVC-I-frame-only has about same efficiency than mpeg2-I-frame only and dv-codec.
So the datarate reduction is made by sacrifing piqture quality.
Unless Panny is making a whole new codec.
If its targeted to mainly eng then it might be good enough for them.Somewhere around 2009 when Panny and Apple will both have support for this AVC-I also with European framerates (25/50fps) everybody else will be using wavelet codecs, which offer way much better quality…
Steve Mahrer
April 26, 2006 at 3:38 amFor those folks not able to attend the NAB and see the H.264 Intra demos at the Panasonic Tech suites, here’s a few facts:
The Panasonic implementation of H.264 is INTRA frame, ie. a GOP of 1. We use the Hi-10 profile,
so that’s HD at 10 bits, not 8. The quality of the 50Mbs H.264 Intra is subjectively the same as
that of DVCPRO HD at 100Mb/s. The 10 bit implementation of the CODEC provides very clean grey scale tonal values. The efficiency of 50Mb/s H.264 Intra provides markedly superior picture quality to that of long GOP MPEG-2 at bit rates of up to 50 Mb/s. Also there are no GOP quality “variablities”, no frame / GOP content interaction, and no issues or worries of concatenation with other long GOP CODECs, e.g. ATSC.This implementation of H.264 provides stunning picture quality and is optimized for field capture / editing purposes, the INTRA frame structure makes software encoding / decoding many times simpler as compared to long GOP systems as each frame is intra-frame encoded.
Long GOP H.264 is ideal for use in applications like content steaming or packaged media as it’s more efficient, e/g Blu-Ray / HD-DVD, satellite etc. An example can be seen where we are showing Blu-Ray playing stunning quality HD using H.264 at a mere 16Mb/s. Viewed on a 65″ 1920 x 1080 plasma you are seeing critical focus errors from 35mm transfers of major movies….
I hope this helps clear up the confusion / speculation around our implemtation of the new H.264 codec.
Cheers!
Steve Mahrer (Panasonic Broadcast)
Toke
April 28, 2006 at 1:17 amThanks for the info, Steve!
Here we have existing AVC profiles:
https://en.wikipedia.org/wiki/H.264/MPEG-4_AVCIn ISO standard, “High 10” is 4:2:0 only. Are you finally changing to lower chroma resolution?
Where do you basis the efficiency of “High 10” i-frame only (other than being 4:2:0 compared to dvcprohd’s 4:2:2)?
Isn’t High10’s i-frame almost identical to mpeg2 i-frame?
Adaptive macroblocking doesn’t make very big difference in i-frames, does it?Why didn’t you choose any modern wavelet based codec for your new format?
