Activity › Forums › Apple Final Cut Pro Legacy › PSD Files Won’t Import Correctly to FCP
John Baumgartner replied 11 years, 10 months ago 6 Members · 15 Replies
Bob Flood
January 4, 2011 at 4:07 amHi
Whenever i try and import Layered PSD’d, they come in as sequences, not stills.
when i double click em, they open in the canvas.the only way i can use em as images is by dragging em to the timeline
is this what you are seeing?
“I like video because its so fast!”
Bob Flood
Greer & Associates, Inc. -
Anthony Bari jr.
January 4, 2011 at 4:21 amPSD’s open as PS seq’s in FCP, the have all the layers intact and you are supposed to use them as sequences. You can use the layers all in tact within the sequence. Also, you copy and paste from that sequence into your main edit if you want. This is what PSD do when imported into FCP.
Hope that helps.*Production*Post-Production*
Apple Certified Instructor (Final Cut Pro 7)
“Semper Fi USMC” -
John Pale
January 4, 2011 at 4:39 amYou don’t change that. Thats how it works.
If you don’t want them to be layered sequences flatten them to get rid of the layers.
If you want to load them in the Viewer instead of dragging to the timeline, right click and select Open In Viewer.
Martin Bentsen
January 4, 2011 at 5:26 pmNo I saw the opposite. They are normally supposed to come in as sequences so you can edit the layers in FC. I was worried about it because they weren’t and I needed them to.
Martin Bentsen
Executive Director,
MJB Home Entertainment, LLC
Graphics/Special Effects/Photography/Videographyhttps://www.mjbhomeentertainment.com/
John Baumgartner
October 23, 2014 at 5:41 amI had the exact same problem, PC PSD files creates in Photoshop CS5.5 wouldn’t come into FCP7 as layered. I finally fixes this when I found Photoshop 5.5 for Mac (I had a CS1 on the mac), installed it, then reserved all the PC PSDs and then they finally imported correctly as layered. For some reason, using the EXACT same version of PS (albeit one for Mac not PC) did the trick. Good luck.
