Activity › Forums › Apple Final Cut Pro Legacy › ProsRes capture hdv & workflow
David Roth weiss replied 18 years, 4 months ago 6 Members · 17 Replies
Jeremy Garchow
May 17, 2008 at 6:16 pm[chris gorman] “ProRes 8 bit.”
Can you please take a screen shot of that?
The video coming in is 8bit yes, but ProRes is 10 bit. If you want you can choose to render it down to 8bit in the timeline, but it’s natively 10bit.
Jeremy
David Roth weiss
May 17, 2008 at 6:18 pmChris,
Stripe two 500Gb drives as Raid-0 and you get a single virtual drive that is essentially 1Gb and nearly twice as fast.
You are more than likely confusing Raid-o with Raid-1 (mirroring), which provides a crappy backup solution, cutting your drive space in half while also cutting down throughput.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Chris Poisson
May 17, 2008 at 8:53 pmGuys,
Give it up on the difference between 8 and 10 bit. In most situations, 8 bit is fine, don’t worry about it. Very few exceptions where 8 bit won’t do the job, especially in cases where original footage is 8 bit, or if that’s what it’s going to.
Have a wonderful day.
Jeremy Garchow
May 17, 2008 at 9:20 pm[Chris Poisson] “Give it up on the difference between 8 and 10 bit”
Sorry can’t let this one ride as ProRes is not 8bit.
Jeremy
Chris Gorman
May 17, 2008 at 9:22 pmI made the screen cap but don’t know how to attach an image here. i see there’s a tutorial, but i don’t understand it and don’t have the time now figure it out.
i was hoping to be able to tell you a page in the manual but can’t find it there. for sure it’s there in the sequence pre-sets for fcp6
Chris Gorman
May 17, 2008 at 9:34 pmI was never wanting to capture 10 bit for this hdv footage. But even with 8 bit, I’m wondering a couple things. How much lag time would I get capturing a 45 minute reel over fw without a capture card?
My 48 sec. test capture, i think had about 18% lag time. Would the RAID0 over fw have less lag time even though I’d still be coming in over fw?
Also, re: drive space, even with two 500GBs as RAID0, doesn’t the speed slow down as the drives get more full, so you may not gain anything if you start with the RAID0 half full or a bit more before rendering etc.?
David Roth weiss
May 17, 2008 at 9:51 pmJeeze, just stripe those suckers Chris and get on with your life. I asked you what you waiting for 16 posts ago. I would not have advised you to stripe them if there were not very good benefits.
All SATA raids slow somewhat as they fill up, that “somewhat” is just a small percentage of the increase you gain by striping.
David Roth Weiss
Director/Editor
