Activity Forums Apple Final Cut Pro Legacy ProRes performance over USB 2.0?
  • Gary Adcock
    August 20, 2008 at 2:19 pm
    [Jeffrey Buras] “Are you sure?”
    YES he is very sure….
    so am I
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Steven Gonzales
    August 20, 2008 at 3:18 pm
    USB might work in a pinch, but that pinch is where your reputation goes down the drain.
    For example, if you’re laying off to tape on a tight deadline, and you get a glitch everytime you edit to tape (albeit at a different spot) then the slightly higher price for a better drive subsystem seems money well spent.
    This board is biased in favor of a professional way of working, which means reliability under all circumstances.
    For the customer, any technical glitch is a failing of the editor.
  • Justin Cordes
    January 21, 2009 at 8:23 am
    How do you guys feel about a G-Tech “G-Raid2” connected to my iMac (2.4 Intel Core 2 Duo) via Firewire 800 for editing ProRes 145? Is it really better than, say, a single LaCie d2 Quadra drive via Firewire 800?
  • David Roth weiss
    January 21, 2009 at 3:01 pm
    The two drives in the G-Raid can be configured three ways, as two independent single drives ( JBOD), as Raid-0 (the two drives striped together), or as Raid-1 (mirrored).
    If the two drives in the G-Raid are striped together in a Raid-0 (as it comes from the factory) the throughput will be considerably higher (nearly 2x) that a single drive.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Tutu Rurah
    March 18, 2009 at 8:59 am
    hello,
    I’ve just got a hmc151 that works with sd cards, and the only connection cable available is a usb 2.0.
    since I work on a MAC how do I do to transfer data to fcp?
    thanks you very much for your advice
    Jimena
    tuturura
  • Rafael Amador
    March 18, 2009 at 11:24 am
    I don’t know much about the PANA, but this may helps you:
    https://www.dvuser.co.uk/images/img/news/panasonic-ag-hmc151/editing-avccam-fcp.pdf
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Shane Ross
    March 18, 2009 at 2:20 pm
    You use LOG AND TRANSFER…you use that for all tapeless formats, and firewire is not needed. You only need firewire for TAPE capture.
    Shane
Page 2 of 2
