Activity › Forums › Apple Final Cut Pro Legacy › ProRes clips need to render in ProRes sequence?
Stuart Page replied 9 years, 10 months ago 8 Members · 16 Replies
Shane Ross
September 5, 2010 at 3:27 am[John Pale] “CP 7 is not supported on PowerPC”
GOOD CATCH! Now we see what happens when people try…
Shane
Read my blog, Little Frog in High Def -
Donal O kane
September 5, 2010 at 1:52 pmYou could also try and see if the alpha settings are different from your sequence
(modify->alpha type … should be set to none/ignore)
Chris Linke
September 6, 2010 at 2:11 amDo you have the Video Scopes open? I seem to remember working on a ProRes sequence once with the scopes open and everything was redlined.
Chris Linke
PRC Digital Media
http://www.prcdigital.com -
Alec Beard
December 6, 2010 at 11:50 pmI’m having this same problem too, and I’m using a G5 running Final Cut 7. That might be the problem, huh?
Shane Ross
December 7, 2010 at 12:18 am[Alec Beard] “I’m using a G5 running Final Cut 7. That might be the problem, huh?”
Running a hacked FCP to run on an non-intel? A configuration that Apple does not support (did not test either)? Could be the problem…
Shane
Stuart Page
November 16, 2016 at 5:25 amDo you have the Video Scopes open? I seem to remember working on a ProRes sequence once with the scopes open and everything was redlined.
Chris Linke
PRC Digital Media
https://www.prcdigital.comYou’re a genius, Chris Linke! I did have the scopes open, and it was showing the red render line when pasting in a new ProRes clip. After reading your tip, I reset the window to a Standard layout, pasted down a new ProRes clip and VOILA! NO RED LINE !!! THANKS !!!
