Activity › Forums › VEGAS Pro › ProRes 422 files stop working in Vegas Pro
  • Aaron Star
    February 15, 2016 at 9:50 am
    When you do conversions from Prores to another format, make sure your levels and gamma are the same on the scope.
  • John Rofrano
    February 15, 2016 at 3:06 pm
    [Jeff Randle] “When using SVP13 to convert 10-bit ProResHQ to MXF, will it maintain the 10-bit status of the file?”
    No it will not. Sony MXF is 8-bit.
    [Jeff Randle] “I use a BMCC and shoot in 10-bit ProRes and am looking into how to maintain that 10-bit status by converting the ProRes to Cineform, MXF, or whatever file type can be used natively in SVP13 so as to maintain that 10-bit status. (so, I hear that’s how to do it).”
    CineForm AVI will maintain 10-bit for you.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Jeff Randle
    February 16, 2016 at 8:18 pm
    THANK YOU!
    You are my hero. :>)
  • Aaron Star
    February 16, 2016 at 8:37 pm
    What is the size of the new file after combining the files?
    Were you able to determine the number of files on the timeline that vegas stopped working?
  • Jeff Randle
    February 17, 2016 at 12:32 am
    Well, I have spent all day trying to find out how to convert my 10-bit Prores to 10-bit CineForm AVI.
    I tried GoPro Studio but it will not import my ProRes files. It says, it “is not a valid GoPro CineForm clip”.
    So, how would I make this conversion?
    Thank you so much for your time.
    I don’t know what I’d do without access to a pro!
  • George Dean
    February 17, 2016 at 12:48 am
    I suspect there are several ways Jeff. I’m using TMPGEnc Video Master Works 6. It’s about $122 with a 30 day trial version. The GUI is relatively easy.
    Best Regards……George
  • Scott Francis
    February 17, 2016 at 2:08 am
    I use these converters as well and have had good results. MUCH faster than Vegas too!
    https://hypedphoto.com/ezencoder.cfm
    Xavier (Scott) Francis
    Mind\’s Eye Audio/Video Productions
  • John Rofrano
    February 17, 2016 at 12:10 pm
    [Jeff Randle] “So, how would I make this conversion?”
    Set your Vegas Pro project to a Pixel Format of 32-bit. Once you have GoPro Studio installed you can create a template for CineForm AVI following my tutorial:
    Creating Cuneiform Templates in Vegas Pro
    Then drop your ProRes 422 footage onto the timeline and render to CineForm. This should maintain a 10-bit file. You can use a utility like MediaInfo to check.
    ~jr
Page 2 of 2
