Activity › Forums › Apple Final Cut Pro › ‘project’ has missing or offline titles, effects or generators etc
Tim Wilde replied 6 years, 9 months ago 7 Members · 11 Replies
Tim Wilde
December 8, 2019 at 12:27 amI ended up at this thread with the same error message but in my case the cause was:
After sweetening in LPX I imported the resulting audio file into FCPX and aligned it with the existing video and audio. I then detached the original audio so I could disable it.
The next day, when I booted up and started using FCPX it started issuing the “missing…” warning every time I tried sharing or sending to Compressor. There was an exclamation point on the project icon. When I made a snapshot of the project as recommended in this thread, the snapshot also had the exclamation point.
The solution turned out to be simple: delete the disabled old audio track.
