Activity › Forums › Apple Final Cut Pro Legacy › Production Monitor BT-LH1700W or Plasma?
Chris Cottrell replied 14 years, 6 months ago 6 Members · 13 Replies
Adam Smith
July 5, 2007 at 5:29 am[Bill Stephan] “They do have a pronounced green cast in the mid-tones (supposedly to make the flesh tones a bit nicer). The green cast is easily seen on a monochrome image. It’s almost impossible to use these monitors for color correcting.”
Hmm… well that’s not good. Thanks for the heads-up.
Walter Biscardi
July 5, 2007 at 11:52 am[Bill Stephan] “We have a 1700 in our tape room and a 2600 in our HD edit room, and I don’t like them. They do have a pronounced green cast in the mid-tones (supposedly to make the flesh tones a bit nicer). The green cast is easily seen on a monochrome image. It’s almost impossible to use these monitors for color correcting.”
Wow, that’s the first I’ve heard of that. I’ve looked at these monitors several times and have never seen this. Sounds like it should be something very obvious from the way you describe it, but I have not seen this at all. I’ll have to ask my Panasonic contacts about this and why you’re seeing such a green cast. I wonder if it’s something in your setup since you’re seeing it on both monitors.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Chris Cottrell
March 9, 2012 at 7:19 pm[Bill Stephan] “The green cast is easily seen on a monochrome image”
Are you seeing this image on your monitor when shooting on a white background? If so it could be a panel issue.
We have worked on dozens of these units. Its is a common problem, but I can assure you it is not “normal”.
Unless I completely mis-interpreted your post 😛
