Activity › Forums › VEGAS Pro › Problems with rendering and the dvd not playing in the dvd player…any suggestions?
Beazly Johnson replied 17 years, 10 months ago 3 Members · 11 Replies
Beazly Johnson
December 1, 2008 at 4:43 amResponding to both comments:
The template I am using is:
DVD Architect NTSC Widescreen Video Stream.
I then select Custom-Audio-Include Audio Stream.
The Bit rate is 224.If you don’t mind me asking. What exactly is a Bit Rate? Will a lower bit rate have a large effect on the quality of the video.
Thank you for the advice on DVDs.
I should add…that I somehow got it to work by adding in chapters on the DVD architect and by making the burn rate slower. Quite baffled by it.
Thanks again,
Beaz
