Activity › Forums › AJA Video Systems › Problems with Kona 3 and ProresHQ-SOLVED!
Mark Maness replied 18 years, 6 months ago 11 Members · 14 Replies
Sara Shier
October 3, 2007 at 5:33 pmHi there…
Yes, I figured out the 5GB thing and am now running 4GB. I spoke to AJA again and it is a problem that some machines are having – not all, but some. The tech support guys told me that both Apple and AJA are aware of it but nobody’s really doing anything yet. They said it’s something to do with filters that Apple puts on the RAM?? So it is a real problem but they did provide a work-around. -
Connie Simmons
November 2, 2007 at 8:40 pmHi. I am still having problems with audio sync and duplicate/skipped frame with prores HQ. May I ask what your settings were and what kind of original footage you had? Thanks, Connie
Lauren Mcguiness
February 20, 2008 at 2:53 pmAnother thing you might want to check out is your expansion card preferences.
Go to system/library/coreservices and make sure it is running at maximum speed.
after we had tried the 2 gig solution, we put back in all the RAM adjusted those settings, and everything is now working fine. -
Mark Maness
February 20, 2008 at 5:04 pmSounds fine…
But if you are running the ATI X1900XT video card, you have to run it at 16x in the slot configuration. This means that you can’t run your AJA Kona 3 at 8x (full time). The only selection that you have available is the 4x-8x combo selection.
So, how does this work for you?
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey
