Activity › Forums › DaVinci Resolve › problems rec709 to dci_xyz in resolve
Juan Salvo replied 13 years, 2 months ago 4 Members · 11 Replies
Juan Salvo
June 8, 2013 at 5:00 amSure it can. You just need to add a shaper lut. I’m a bit confused by what you mean working full range internally but grading out to head range? If inside resolve your intended black point (let’s say it’s true black) is falling on 0 and your intended white point is on 1024. Then you’re working full. If it’s at 64-960 (internally in resolves scopes, regardless of outside scopes) then you’re not working full, and would need a shaper lut feeding into the 3d transform.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
