Activity › Forums › Apple Final Cut Pro Legacy › Problems outputting hour long show
Alan Loshbaugh
September 4, 2012 at 9:47 pmthis did not work.
audio was off by 10 minutes or more.right now, i’m exporting xdcam mxf files to the desktop, to ftp to a blue ray.
Mark Suszko
September 5, 2012 at 12:54 amAt this point I think your best bet is to do a simple author to BD using Toast or the “share” function off the timeline. Assuming you had access to a burner for the BluRay. I must confess your story distresses me because i was aiming to be able to play off the timeline into a stand-alone BluRay recorder as you describe, but all I have right now is an external BD burner, so any BD I make has to be “authored” first.
Alan Loshbaugh
September 5, 2012 at 12:59 amOK:
I don’t understand your post Mark;)But: my facilis media storage is showing all kinds of system errors.
Last time it did this, it was because one of it’s 26 drives was failing, and I think this is my issue now.Not sure how I can fix that before an 8am satellite window though.
Matt Mullen
September 5, 2012 at 4:47 pmAlan,
E-mail me the system event log from the Facilis.
I want to make sure there isn’t anything on that end causing the problem.
matt@facilis.com (e-mail me if you need instructions).
Alan Loshbaugh
September 5, 2012 at 5:54 pmI can’t do that, but, I can put you in touch with the guy that can.
I think your staff have been remoting in to try and diagnose/fix things.thanks for asking; that reflects a high level of service from you guys!
alan
Matt Mullen
September 6, 2012 at 5:49 pmThanks Alan.
We do our best. Glad we got it sorted out for you. Don’t hesitate to contact me if you need anything else.
-Matt
