Activity › Forums › Apple Final Cut Pro Legacy › problems going FCP to AE back to FCP
  • Victor Jory
    July 21, 2011 at 6:43 pm
    You are sending NTSC and he is sending you something different.
    Have a look to the Browser > Pixels aspect.
    Make sure the animation files show up as “Squared Pixels”.
    I have done this as well- it does correct any squishing issues but it doesn’t effect the finished output QT resolution being significantly different.
  • Rafael Amador
    July 21, 2011 at 8:22 pm
    [victor jory] “I have double clicked a clip in the browser and changed the field in the “item properties” to none, upper, and lower. I have then altered it in my sequence setting trying different and same combos to no avail.”
    You can’t change Properties once the clips in the time-line.
    Change the Pixels Aspect or field-order (Browser), then lay the clips in the time-line.
    rafael
    http://www.nagavideo.com
Page 2 of 2
