Activity › Forums › Apple Final Cut Pro Legacy › Problem with FCP/alpha channel…
Jeremy Garchow replied 19 years, 5 months ago 3 Members · 17 Replies
Jeremy Garchow
April 4, 2007 at 2:51 amIt looks like bad compression to me . i have seen that exact look from crappy Mpeg-2 compression which leads me to believe it’s a goofed up render.
You meant millions of colors+, right? What kind of alpha did you render (pre-multiplied, or straight) and then you double checked that in FCP (i know we’ve been over this, but sometimes it’s only a little switch that is is forgotten to be flipped).
DPI has nothing to do with video. Higher DPI won’t gain you anything, only frame size will gain you resolution in video.
I am in Chicago by the way.
Eduardo Chacon
April 4, 2007 at 3:19 amI thought you were asking about the final render of the commercial.
Yes, the logo movie is of course millions +. Remember that the other logo is an RGB Photoshop file so there’s no render.
Also the alpha in the logo is straight and so it’s checked in FCP.
The reason I used the 15-inch 300dpi logo was to try something radically different from the logo movie to see if it would render a similar problem.
If you send me your email i’ll email you a link to my ftp site so you can download an FCP project with the relevant files.
Thanks again. -
Jeremy Garchow
April 4, 2007 at 3:36 amCheck my profile. I am only going to leave it up there for the next 15 minutes. Let me know if you got it and then I can remove it.
Jeremy Garchow
April 4, 2007 at 4:03 amClick on View Profile next to my name, it’s listed in the ‘about JeremyG’ line.
Jeremy
Eduardo Chacon
April 4, 2007 at 4:08 amThere’s nothing next to the ‘about JeremyG’ line.
Send me an email at:
jarane@yahoo.comThanks again.
