Activity Forums Apple Final Cut Pro Legacy Probably a DUMB question but…
  • Probably a DUMB question but…
    Posted by Jim Branstetter on April 21, 2005 at 1:59 am
    Hi All,
    When I render a sequence in FCP, I get a with a narrow white strip across the top of the frame. I have never had this problem and after going through all my settings can’t figure it out. What is it? This project file came from a client.
    Any ideas ?
    THANKS!!! in advance,
    Jim
    Jim Branstetter replied 21 years, 5 months ago 8 Members · 11 Replies
  • 11 Replies
  • Scott Davis
    April 21, 2005 at 4:18 am
    Is it a DV vs. D1 issue? (640×480 vs. 720×486)
    Scott Davis
  • Sean Oneil
    April 21, 2005 at 6:00 am
    That’s not a dumb question. So you’re saying it looks fine but when you render you get a white strip?
  • Shane Ross
    April 21, 2005 at 7:09 am
    [Scott Davis] “Is it a DV vs. D1 issue? (640×480 vs. 720×486)”
    Scott…DV is 720×480 and D1 is 720×486.
    Just FYI.
    Where is this white line? Is it consistant thru all your footage?
  • Jim Branstetter
    April 21, 2005 at 7:56 am
    Thanks for responding..
    first; it is a thin (about 1/8″) white strip across the top with the word “” just like its typed in the center of the white strip, of the rendered footage, footage rendered ar 720×480 DV
    second; sequence settings ntsc dv at 720 x 480
    third; looks fine in FCP but the strip shows up in the render, I rendered both a QT and a FCP QT movie and it showed up on both.
    I’m stumped
    Thanks!!!
    Jim
  • Jim Branstetter
    April 21, 2005 at 8:22 am
    and it says “cut” across the top in the white strip bracketed with the greater & less than symbols
    Thanks Jim
  • Tom Matthies
    April 21, 2005 at 1:47 pm
    I don’t know which one it might be, but is it possible you might be running a demo version of some software that will “watermark” your video when it’s rendered?
    Seems strange it shows up only after you render.
    Just a thought…
    Tom
  • John Fishback
    April 21, 2005 at 2:21 pm
    It sounds like you are seeing the markers that are written by FCP to tell Compressor where transitions occur in the program. I saw this once when I exported a QT. When I checked my export setup I had Markers set to DVD Studio Pro and saw them in a thin band across the top of the exported QT.
    It’s possible that your client exported the footage this way and you don’t see the band until you render it. Just a thought.
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
  • Walter Soyka
    April 21, 2005 at 5:30 pm
    I agree — sounds like the marker track.
    You can open the media file in QuickTime Player Pro and disable the text track. The markers will still be accessible via Quicktime, but they won’t be visible in your video anymore.
    Regards,
    Walter Soyka
  • Stinky Grinch
    April 24, 2005 at 8:22 pm
    How do you disable the text track? I’m new to this as well and im seeing the white stripe with chapter data in it on my exported quick time files. I am not sure that I have quick time pro installed. I know I have quick time just not sure if quick time pro is different or where I would look for those settings.
  • Walter Soyka
    April 25, 2005 at 6:45 pm
    You get a QuickTime Player Pro name & serial number when you buy FCP. Look for it in your box. Enter it under QuickTime Player -> Preferences -> Registration.
    Once you do that, open up your media file in QuickTime. Edit -> Enable Tracks. Find the text track, and click the ON button — it’ll turn to OFF. Click the Ok button, save the file, and you should be all set. The chapter markers are still there, but they won’t appear in your video.
    Regards,
    Walter Soyka
