Activity › Forums › AJA Video Systems › preview HD on SD monitor REALTIME
Scott Robert
September 7, 2008 at 11:17 pmThanks guys. I can now view HD downconverted to my SD monitor.
Jeremy Garchow
September 8, 2008 at 3:21 amBy the way, I was wrong about the Kona 3, you can in fact do a 2K crop to 1080 and then do an SD down conversion.
Glad you’re up and running.
Jeremy
Christopher S. johnson
September 9, 2008 at 10:54 pmHi,
I have a Kona LHe and recently had a Red 2k project that I used a batch process in Compressor to crop for 1080. Was that a waste of time? Is there a better way? I needed my clips to be real native clips in my 1080 timeline with no green RT bars.
-Christopher
Scott Robert
September 10, 2008 at 2:42 amIt would be a waste of my time if I did it. Not sure for you. The 4k clips in my 1080 timeline gets the green render bars but without rendering, it plays back perfectly. If I have another video under it, the quality shows reduction. After the log and transfer was completed, I start editing right away with no problem.
