Activity › Forums › Adobe After Effects › Presentation in After Effects
Ryan Smith
February 22, 2013 at 1:37 amIMO Best way to do this is to use encore and create a dvd presentation. Then use your smart device and download an app like unified remote to control the media off of the cpu hooked up to the projector. If no pc then just use a dvd player + it’s remote and plop in the dvd. I’m sure if you had to do a conference you could bring ur dvd player with yah. Obviously encore gives you all yah need since it can stop at certain points and loop videos etc.
Just another option I’m tossing out there. 🙂 The whole laptop thing would be the best way if the wifi was easy to access since dvd remotes suck ass distance wise. 🙂
Thoughts?
Muhammad Saeed
November 8, 2013 at 11:32 amI add a silly idea that may help, and this is based on my experience in powerpoint not in AE.
My idea is to save the movie file created by AE in a format that can be played by powerpoint inside the slide. Then after adding the video in to the powerpoint slide, you can the required number of pauses and plays using the animation window. This is based on the fact that you are aware of how many times you will stop to speak about the slide, and also the locations of this stopping points. You can also paly and stop and replay again using the next button in your pointer if you are using any.
If my idea is not clear, feel free to contact me.
Dévin Van cruchten
September 7, 2014 at 5:45 pmPlease explain me how to do this… 🙁
It’s driving me crazy and i can’t find any tutorial that explains this… in EncoreI want some slides to loop.. (and then when i click ”next” it has to complete the loop before going to the next so the transition is smooth)…
i want some slides to serve as just a transition to another loop..
I want to create a very advanced, animated presentation and i hope you can help me do it..
