Activity › Forums › RE:Vision Effects › Premiere CS5.5 + Twixtor – Big Problem!
Pierre Jasmin replied 14 years, 10 months ago 3 Members · 21 Replies
Pierre Jasmin
August 9, 2011 at 8:48 pmFirst Keyframe value: Yes I noticed this too in other tools as well. There seems to be an issue with the first keyframe you apply in CS5.5.
If you type 100% at frame 1, then move to frame 60 and type 60% now keyframe 1 is 60%, you have to go back to frame 1 and reset. Looks like a Premiere bug.Pierre
Piotr Abramowski
August 9, 2011 at 8:56 pmSo do I have to wait for the premiere cs5.5 update? yes?
I did another test – and exported to mpeg2 movie – the film looks good, slows down, the premiere cs5.5 but this can not be smoothly mounted …
Pierre Jasmin
August 9, 2011 at 9:01 pmNO, just go back to first keyframe and retype value and then it’s OK
That seems to work then. -
Piotr Abramowski
August 9, 2011 at 9:06 pmUnfortunately, as I get back to the first frame and the short term it back to 100% – premiere cs5.5 render the file again.
After the value to render the first frame again is at 60% and so on ….
Pierre Jasmin
August 9, 2011 at 9:15 pmNOT SURE I UNDERSTAND
Can’t you set all the keyframes, and then hit “Enter”?
Pierre
Piotr Abramowski
August 9, 2011 at 9:18 pmI set all the keyframes and hit “enter”
….. and then again the same thing – values now agree, but the timeline on getting the red …..
Pierre Jasmin
August 9, 2011 at 9:22 pmIt works for me here
Maybe make sure the keyframe is not selected? -
Piotr Abramowski
August 9, 2011 at 10:13 pmunfortunately nothing helps .. I do not understand what’s happening.
I have the impression that all this wine premiere cs5.5: (
I do not know what to do
Pierre Jasmin
August 9, 2011 at 10:53 pmPiotr,
I guess we are back to send me a project and movie, it does not do that here…
go here:
https://revisionfx.com/support/contact/
It will send you ftp instructionsPierre
David Lavender
November 15, 2011 at 5:01 amDid this get resolved, Pierre? I’m having the exact same problems. Twixtor worked great in CS5, but since I upgraded to 5.5, the keyframing is a nightmare. Like the OP, when I render, rewatch, and move the timeline indicator, the twixtored clip immediately goes red again, as if I never rendered. Super frustrating. I’d love to know if this was solved.
