Activity › Forums › Sony Cameras › pmw-ex1
Aaron Leong
September 18, 2009 at 5:45 pmDaniel, I use the XDCAM Transfer application, instead of the Log & Transfer within FCP.
When I first started using the EX series I used the Log & Transfer and it started failing me, as in it would freeze, or just wouldn’t render the footage. I downloaded XDCAM Transfer and it has worked flawlessly for me. Although I hear that the Log & Transfer within FCP is much better now. I’ve yet to use it since upgrading to FCS 3.
In XDCAM Transfer all you have to do is select the clip(s) you want to render, and click on ‘import’. Thats it. Make sure you set where the clips are imported in the preferences and you’re good to go. Hope this helps.
Michael Slowe
September 19, 2009 at 2:00 pmI am really AMAZED that not one of you has mentioned the one huge difference between the EX 1 and EX3 – the VIEWFINDER. The glass over the screen on the EX3 makes it so much easier to focus, especially in bright daylight. I stuck to the EX1 because it’s lighter and does all I need but I do find it tricky to focus with that screen – so much so that I’m investigating the possibility of fitting the finder from the 3 on to the screen of my camera.
Also I can’t understand all the talk over the workflow. The Sony Transfer does a great job in presenting all the clips from a card (file) which you can edit before importing straight into your chosen NLE – Media 100 in my own case. Just the same as with tape but faster.
Michael Slowe
Craig Seeman
September 19, 2009 at 4:06 pm -
Marvin Holdman
September 19, 2009 at 6:40 pmAssuming you are working with FCP, here is one;
https://www.sony.co.uk/res/attachment/file/95/1133797571595.pdf
Another good starting point for this camera is Noah’s fine video on the subject. You will find it here;
https://www.callboxlive.com/products/sony-ex1-guidebook
Marvin Holdman
Production Manager
Tourist Network
8317 Front Beach Rd, Suite 23
Panama City Beach, Fl
phone 850-234-2773 ext. 128
cell 850-585-9667
skype username – vidmarv -
Danny Soderberg
September 19, 2009 at 11:53 pmThanks for the links, though I actually use Adobe Premiere and After Effects to edit.
-Daniel -
Craig Seeman
September 20, 2009 at 12:05 amYou’d think Sony would update their Premier Pro guide from CS3 to CS4. Sheesh.
Ron Pestes
September 24, 2009 at 12:33 amGuys, there are several BIG differences between the EX-1 and EX-3. The viewfinder on the -3 is a HUGE advantage over the -1. I have shot with both and own an EX-3. It also is MUCH easier to hold steady handheld because it is shoulder mounted. The lens and multicam cabability are great too.
Also, there is no problem with using XDCAM Transfer to download your clips. It is fast and you can drag them straight to FCP with no render. FCP makes a compatable timeline automaticly. This is about as easy as it gets.
