Activity Forums VEGAS Pro Plural eyes and Vegas 17
  • Plural eyes and Vegas 17
    Posted by Martin Phillips on April 13, 2020 at 3:43 pm
    Hi all, is there a workaround to get pluraleyes 4 to appear in the extensions of Vegas 17. I’ve noticed there is a Vegas sync audio in the multi-cam menu but so far it’s taken 2 hours to do 2 % of a 140 minute 4 camera timeline. Thanks Martin
    Brian Bosco replied 5 years, 2 months ago 6 Members · 15 Replies
  • 15 Replies
  • John Norton
    April 17, 2020 at 12:04 am
    Copy the file “PE4Vegas14.dll” which is in the folder .. C:\Program files\Red Giant\Pluraleyes 4\
    then paste it to … C:\ProgramData\Vegas Pro\Application Extensions\
    or … “PE4VegasLoader14.dll” rather than “PE4Vegas14.dll”
  • Paul Berk
    April 17, 2020 at 4:28 am
    Thanks John. This worked perfectly.
  • Martin Phillips
    April 17, 2020 at 7:49 am
    Hi John,
    Thank you for your response – that worked perfectly.
    Thank you.
    Regards
    Martin
  • John Norton
    April 17, 2020 at 1:06 pm
  • Brian Bosco
    July 7, 2020 at 5:06 am
    I have a working copy of Vegas Pro 17 and a working copy of Pluraleyes 4.
    I can open Pluraleyes on it’s own….but it tells me it must be opened within SV17 to sync my project.
    I created the directory: C:\Program Files\VEGAS Pro 17.0\Application Extensions
    I’ve tried pasting the following into Application Extensions:
    PE4VegasLoader8.dll
    Yet, neither shows up in extensions.
    Any idea what I could be doing wrong?
    I also tried uninstalling programs, cleaning registry of leftover files, then reinstalling programs.
  • John Norton
    July 7, 2020 at 9:40 am
    Hi Brian, its ProgramData.
  • Brian Bosco
    July 7, 2020 at 8:40 pm
    Thanks for your quick response John,
    Yes….it’s in the ProgramData (I made a typo)
    Still does not show in SVP17 extensions.
    I’m under the gun with a 9 camera project….over 50 clips of staggered media which will take me many hours to sync manually. I’ve used PluralEyes successfully in the past….but this is a new editing computer with plenty of muscle and it just doesn’t want to let me use PluralEyes for some reason.
    Your help is greatly appreciated.
  • John Norton
    July 7, 2020 at 10:29 pm
    Hi Brian, I’m afraid that’s all I can think of, save to completely uninstall vp and or Pluraleyes maybe both. Then try again.
  • Francois Pénzes
    July 7, 2020 at 10:35 pm
    Hi Brian
    Have you tried Red Giant Support ? They are usually pretty quick.
    https://www.redgiant.com/support/
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • John Norton
    July 7, 2020 at 11:29 pm
    One other thing Brian, vp17 has a built in syncing feature, apparently it works best if you select only a smaller selection, not necessarily all media at once. From my memory of users on the Magix vp forum, uninstalling and re installing Pluraleyes can remedy the situation.
