Activity › Forums › Adobe Premiere Pro › Pluggins for Premiere Pro
Tom Daigon
May 15, 2012 at 12:51 amBrian, you need to be the judge of course. Check out my review then go to the second link which shows just some of the choices. I think you will be a bit surprised.
https://library.creativecow.net/daigon_tom/Boris-Red-5point0-review/1
https://www.borisfx.com/red/Movie-Gallery.php
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Maxx Digital / Areca 8tb. raid
Kona 3 -
Brian Cooney
May 15, 2012 at 12:53 amThanks I will! Noticed you were also thinkign of switching to PC.. they may be coming down the road for all of us hey?
MotionFoundry, Inc. Video Post
Clients: GM, AOL, Kohl’s, 3 Doors Down, Thomas Nelson, NASCAR Affiliates -
Brian Cooney
May 15, 2012 at 12:56 amyeah… the blurs are nice and I like the “super dissolve overlay”.
Tom Daigon
May 15, 2012 at 12:58 amSeems to be the logical thing to do these days considering Apples recent behavior on many fronts.
Tom Daigon
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Kona 3 -
Tom Daigon
May 15, 2012 at 1:00 amAnd you can create your own from scratch using more than just the filters. Lots of power and potential. I only use it for transitions since Im a hard core AE user.
Tom Daigon
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Kona 3 -
Dave Craig
May 16, 2012 at 8:57 amThe only other “REAL” transitions for PP that I’ve found are the NewBlue.effects. they have four transition packs available. Not cheap but decent. Cpu acceleration coming soon for Mac but works really fast on my macbook pro. I really miss my fcp lensflare transitions and FXfactory! Grapevine says fxfactory is working on some goodies for PP!!
Tom Daigon
May 16, 2012 at 1:05 pmI spoke to FX Factory directly at NAB and he said FX Factory would never be coded for PrP due to the differences in OS which was crucial to its functioning.
Tom Daigon
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Kona 3 -
Walter Hickox jr.
May 16, 2012 at 11:59 pmNow my question involves Premiere Pro and Sapphire Transitions. I have searched and have found nothing that hits my issue directly. I found tutorials and not one has worked for me. I just want to know if my issue is a bad installation or ???? No matter what setting I use the clip with the transition applied to it, turns solid red. All the setting tweaks in the world does nothing to change this. Tutorials from anywhere, YouTube.. my monitor turns red while in the tut does not. I also noticed every adjustment I make I can see PP working but rendering a solid red screen. Is there something I’m doing wrong or did I get a bad copy of Sapphire Transitions? It does the same thing in AE too.
Dave Craig
May 17, 2012 at 12:10 amI had heard something different from a source in tech support, but then again that was a year ago and things probably changed. Bummer!!
I’m going to look in to the Boris Red angel if they actually have drag and drop transitions!
Tom Daigon
May 17, 2012 at 3:29 amThey have a transition effect that you drop on the timeline at the intersection of 2 clips.Then you open the GUI and select or build the effects you want. Go to these 2 links to learn more.
Tom Daigon
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Kona 3
