Activity › Forums › Web Design (WordPress, Joomla, etc.) › pls help: Different look in different browsers
Fernando Mol replied 16 years, 9 months ago 4 Members · 13 Replies
Fernando Mol
December 22, 2009 at 1:27 amYou are still sending php variables.
https://www.pakenhamosteo.com.au/staff.html?showTopic=staffYou see? everything after the question mark is the definition of a variable called “showTopic”.
I hope removing them from your links will help you.
*Always share a link to your site and rate the posts. This is a free service for you and for us.
Karen Ness
December 22, 2009 at 1:50 amhttps://www.pakenhamosteo.com.au/staff.html?showTopic=staff
Are you saying that the ? in the above line signifies the begining of the php variable? Do i need to remove the ? and all the code following it from the code in each of my pages to remove all the php. Or is there a simpler way of removing the php from our web page?
There must have been a reason it was put there in the first case, what changes can i expect to the overall performance of the site without the php? -
Fernando Mol
December 22, 2009 at 5:32 amI was talking just about the links in your menu.
I can’t see the PHP code in your site (it’s already rendered to HTML when you saw it on the web) and the code you have pasted doesn’t seems to have any PHP inside. And you swear you pasted all the code from your file in DW in code view. Something doesn’t make sense.
Maybe you need somebody that know a little about PHP in front of your computer, to see all the docs and code in your site.
And yes, there’s a reason this variables are there. But since I can’t see the entire site it’s my best guess to remove them. That way you’ll clean the navigation and probably solve the problem you actually have.
If you could post a screen-shot of the files in your site, that could help.
