Activity › Forums › Adobe After Effects › PLEASE ADVISE ASAP! After Effects will not render SOME assets.
Eugene Baritskiy replied 11 years, 1 month ago 13 Members · 17 Replies
James Hobson
March 26, 2012 at 9:40 am@rc Johnson
Thanks so much – turning on continually rasterize fixed blank RAM preview and renders.. *sigh of relief*
Elizabeth Kaiser
July 12, 2012 at 12:30 amI actually created an account specifically to thank you for this response. I have been trying to figure this issue out for the last hour and I just stumbled upon your answer. It just saved my butt majorly. So thank you. 🙂
Saadi Alkouatli
October 15, 2012 at 3:43 amThanks Walter, you saved me with your answer! I clicked on a layer by mistake and made it a guide layer.
Lucas Moore
July 4, 2013 at 7:01 pmIn my comp, a PSD wasn’t rendering. I had accidentally activated the guide layer. Right clicking the affected layer and un-checking “guide layer” solved it for me. Thanks!
Coby Randal
March 29, 2015 at 1:16 amHey guys, I know this is an old thread, but I wanted to add a solution that helped me out (using After Effects CC 2014).
One of my layers was not rendering because it was set to “Guide Layer”. Simply right click it and uncheck “Guide Layer”. Renders great :D.
Chris Homer
June 29, 2015 at 2:25 pmHey Guys, I have had the same problem today with AE 2015. Turns out the problem was because I had pre composed 3d objects. When I turned off the accept lights off on all the materials in the pre comp the render worked.
cheers
Eugene Baritskiy
July 31, 2015 at 1:10 pmHello everyone. I have the same problem and can’t resolve it. I don’t have any Guide Layers and I am not using AI files. There are just few PNG’s in very high resolution (5760×3240). They are render well if I choose crappy quality, but if I choose Best quality I don’t see anything. Also I see them just fine in After Effects preview (using spacebar).
I have latest After Effects CC on iMac i7 (24Gb RAM).
