Activity › Forums › Adobe Premiere Pro › Playback response slow
Jeff Smith
July 16, 2014 at 9:55 pmok. well it sucks. i’ve disabled the multi cam and its back to original performance. i’ll just have to re-enable further down the road. thanks for info
Elise London
August 1, 2014 at 3:37 pmHi Jeff,
I’m having the same problem as you with the lag playing the timeline. I was quite confused reading this thread, though … the response that you got was quite technical.
Which element in the system was causing you the problem?
Thanks so much! 🙂
Elise London
August 1, 2014 at 9:30 pmI just got off the phone with adobe and found the magic fix (for me at least!) Select entire sequence. Then: Clip > Audio Options > Render and Replace.
Jeff Smith
August 4, 2014 at 3:44 pmFor me, it was multi cam. Specifically, the audio. Once I disabled the multi cam in the audio, it was back to instant playback. Very strange……
