Activity › Forums › Adobe Premiere Pro › playback in premiere is choppy h264
  • Kevin Monahan
    February 5, 2013 at 10:52 pm
    Try these things:
    •Follow these instructions: https://helpx.adobe.com/premiere-pro/kb/playback-stops-loops-soundbooth-premiere.html
    If that doesn’t work, try the following:
    •Import the footage via the Media Browser, not File > Import
    •Drag n drop a clip to the New Item button to ensure you have the proper sequence settings.
    •As was suggested, drop playback res to 1/2 or 1/4
    •Try to play your clips from a different drive, not the T-bolt one.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Kyle Garvey
    February 15, 2013 at 4:30 pm
    Peter, how do I change my preview settings? it the sequence setting window it’s greyed out…
    thanks,
    Kyle
  • Faris Danial
    March 20, 2013 at 9:40 am
    Im having the same problem as well. 2 months back, everything was going well then suddenly my playback is reaally choppy after graded it.
  • Adam Lewis
    May 5, 2014 at 11:07 am
    I finally figured this problem out for me – i started getting the problem after upgrading to mavericks on a 2011 macbook pro i7
    in the sequence settings “Composite in Linear Colour” was ticked – unless you have GPU acceleration, its noting going to play black properly.
    Unticked and it worked.
    Thank god.
    Not seen this solution posted anywhere after a month of searching, so spread the word!
Page 2 of 2
