Activity › Forums › Adobe After Effects Expressions › Play and Pause on markers
Posted by Chris Scalzo on October 21, 2015 at 5:40 pmI know this should be easy, but I’m trying to write a time remap expression freeze and play based on clip markers. I am surprised i couldn’t find this already made. I will post it if I figure it out.
Paul Roper replied 5 years, 4 months ago 4 Members · 18 Replies -
Dan Ebberts
October 21, 2015 at 6:51 pmI’m not sure what you have in mind exactly, but since expressions have no memory, your expression will need to calculate how much play time has occurred in the past by examining each marker previous to the current time.
Dan
Chris Scalzo
October 21, 2015 at 7:42 pmI understood this, and that is the part I’m trying to figure out. I wrote this after sending the post, but I still need to write something for calculating totaltime of the odd or even marker differences.
try{
m = thisLayer.marker;
i = m.nearestKey(time).index;
if (m.nearestKey(time).time > time){ i--;}
if (i < 1) { i = 1};
if (i%2==1) {marker.key(i).time} else {totaltime}
}catch(err){0} -
Chris Scalzo
October 21, 2015 at 7:49 pmMy last post didn’t paste correctly. Something weird between Mac and PC text.
try{
}catch(err){0} -
Chris Scalzo
October 21, 2015 at 7:50 pmCurrently The odd numbers are pause and I’m starting clip off frozen with marker off top.
Dan Ebberts
October 21, 2015 at 7:55 pmIf you’re going to post code, don’t preview your post, or all the < characters will get converted to html codes when you finally post it.
Dan
Dan Ebberts
October 21, 2015 at 8:43 pmI think it will be something like this:
if (m.numKeys > 0){
i = 1;
segStart = 0;
accum = 0;
for (i = 1; i <= m.numKeys; i++){
if (m.key(i).time < time){
if (i%2){
accum += m.key(i).time - segStart;
segStart = null;
}else{
segStart = m.key(i).time;
}else{
break;
if (segStart != null){
accum += time - segStart;
accum;
}else
time
Dan
Chris Scalzo
October 21, 2015 at 8:50 pmLooks good to me. Thanks, your biggest fan (probably not, since you are a rock star).
Chris Scalzo
October 21, 2015 at 10:47 pmOne more thing I’m trying to figure out with another expression I’m using with the previous. I wrote the following expression to toggle an Effect Opacity on and off with keyframes. I can’t figure out how to use easeOut to ramp the transition from 0 to 100 and back to 0 (on following keyframe).
try{
i%2*100
}catch(err){1}
