Activity › Forums › Apple Final Cut Pro Legacy › Pixellated DVD from FCP Project
Dean Longfield replied 12 years, 6 months ago 4 Members · 14 Replies
Mark Suszko
March 5, 2014 at 12:04 amFingers crossed! My gut says somewhere some scaling is going on that’s wrong, so maybe these settings will help, but the player and TV must be set to view native 3:4 Sd programming without altering it, to be sure. To be scientific, we have to eliminate all the variables and tweak one thing at a tim.
Dean Longfield
March 5, 2014 at 2:39 amHey Mark – Thanks for taking the time to help out. Unfortunately the DVD burn still had the pixellation in the same spots. I’m going to try sending it through Compressor…
Chris Babbitt
March 5, 2014 at 2:44 pmDean,
How long is your program? Your bit-rate is appropriate for a 2-hour program, but if it is shorter than that, you can increase it. If it is under 1 hour, I would try a constant bit-rate of 7 or 7.5. Also, encode your audio using Dolby. I’m not sure DVDSP has that feature. You may need to use Compressor.
Dean Longfield
March 5, 2014 at 9:00 pmProgram Time: 1 hour 20 minutes
i made a separate MPEG2 video, and an ac3 audio track, instead of an all contained .mov, and it worked.
Did the above in Compressor.Thanks for all the suggestions. Much appreciated.
