Activity › Forums › Adobe Premiere Pro › Pixelated footage after rendering sequence in Premiere Pro CC 2015
Lee Baltus replied 10 years, 3 months ago 3 Members · 21 Replies
Chris Wright
May 30, 2016 at 3:49 pmi hear you, it looks good in premiere’s monitor, but pixelated upon render. That is why we need to isolate your render settings. and a png trillions(16bit) will remove any questions about compression and 8 bit output at the same time.
Can you post a screenshot of your media encoder settings, file-export media
Lee Baltus
May 30, 2016 at 6:24 pmThnx for your effort. But to be clear when I say rendered I mean rendering the red line to green in my premiere sequence. so not a render like exporting thru media encoder.
Lee Baltus
May 30, 2016 at 6:45 pmSo I just did a sequence render with the logo layer (AE animation export) on top of the gopro and dslr footage and comes out pixelated.. and I rendered the same logo layer on top of a grey color matte.. and it stays sharp.. all rendered in the same Premiere Sequence.
Chris Wright
May 30, 2016 at 6:57 pmit could be the alpha matte in modify-interpret footage alpha matte premultiplied/straight
Lee Baltus
May 30, 2016 at 7:13 pmI also tested that, but same result.. The thing is that nog only the logo layer becomes pixelated but also my canon or gopro footage is pixelated after rendering..
Lee Baltus
May 30, 2016 at 7:29 pmSo that would rule out the AE export settings and premiere export settings right? The problem should be in the Sequence or Render settings? But the only “render” setting I can find is in Project settings/General/Renderer.. only to pick from cuda or no cuda. Already tried that and no succes..
Chris Wright
May 30, 2016 at 7:34 pmat the top of premiere, sequence, sequence settings. then video previews.(click on your active sequence to un-grey it)
“In the Video Previews section, choose one of these sets of preview file formats and codecs, depending on your system:
For Windows, choose Preview File Format: Microsoft AVI and Codec: None (alternatively choose Uncompressed UYVY 422 8 bit).For Mac OS, choose Preview File Format: QuickTime and Codec: None (alternatively choose Uncompressed YUV 10 bit 4:2:2 or Uncompressed YUV 8 bit 4:2:2).”
