Activity › Forums › Adobe After Effects › Pixel aspect ratio in Adobe Media Encoder
Jan Vork replied 6 years, 8 months ago 5 Members · 14 Replies
Desiree Damon
May 13, 2010 at 7:50 pmThis is probably useless to you now, but I was searching the forums frantically looking for an answer to this problem… And then I found something.
In CS5 at least, the aspect ratio controls aren’t found in the export settings. I had to go to file/Interpret footage, then I could change my aspect ratio. Everything went perfectly after that.
Alan Dargan
July 13, 2010 at 12:01 pmDesiree,
I’ve been searching high and low for a solution to this so thanks!
The file interpretation option could be located somewhere a bit more intuitive..
Jan Vork
December 17, 2019 at 1:27 pmHi Knut,
10 years after the OP, I was suffering (and getting frustrated) from the same thing in Media Encoder 2019.
But I found a solution.
It’s not in the settings pane, but in the upper left corner: set ‘Source Scaling’ to ‘Scale to Fill’. That should do what you want. -
Jan Vork
December 17, 2019 at 1:34 pm
