Activity › Forums › Adobe After Effects Expressions › pin position to parented rotating object
Alexander Weil replied 9 years, 4 months ago 2 Members · 14 Replies
Steve Sierra
April 27, 2017 at 9:32 amI think you can now open your cc 2014 and downgrade it again… until you get to CS6.
I linked the dress and the legs to a central pelvis null so that they all have the same “zero”. My shape layer’s anchor point is right on that null, giving a position and an anchor point of [0,0]… Maybe that’s why it doesn’t work for you ?
If you can downgrade to CS6, I’ll have a look at your project. (by the way, is power pin the same as corner pin ?)
Cheers
Alexander Weil
April 27, 2017 at 10:30 amcc power pin – the result is the same but the anti-aliasing is a bit better
i only could downgrade it to cc13 but there is one more step cc -> cs6
i exported a xml file and give you the cc13 file , maybe one of these will work?11306_charstestconverted.aepx.zip
11307_charstestcccopycc12.aep.zip
Steve Sierra
April 27, 2017 at 11:21 amSorry I couldn’t open your files…
Where you able to open mine ?
Alexander Weil
April 27, 2017 at 2:47 pmjeah i could open it and when i moved your Thighs Controller there was the same strange thing as in my comp so i played around with my shape layers position/anchorpoint. there was something wierd with my anchor point, after i put it in the middle everything looked fine ☺
so now it works ☺
thanks bud for your help and time!!
