Activity › Forums › Apple Final Cut Pro Legacy › Perfect FCP to AE workflow
  • Michael Nikitin
    April 28, 2008 at 9:42 pm
    Dave. It worked. I’m speechless. Thanks so much! And a big thank you to the guys at Popcorn Island.
    In case if anyone has the same issue as I did, while having as little scripting experience as I do, here’s what needs to be done (it was not apparent to me what to do with the jsx file, at first), —
    The PI_FCP2AE.jsxbin file goes to After Effects’ “Scripts” folder. Then, you need to run After Effects, go to File->Scripts->PI_FCP2AE, locate your XML (Version 3 worked for me) that you generated in Final Cut, and… voila.
    I am using Final Cut 6.0.2 and AE CS3, btw.
    Once again, thank you Dave, thank you Cow, thank you everyone! Damn! I’m so excited. I want to love the world and dedicate my life to public service…
  • Rafael Amador
    April 29, 2008 at 2:12 am
    [Michael Nikitin] “would it make any difference if I render files out as Quicktime movies, or if I went with “using Quicktime conversion”? “
    Try to avoid “QT Conversion. When you export to QT from FC, only the clips where you have hanged something are rendered. With QT Conversion all your footage is re-compressed. You loose a generation.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
Page 2 of 2
