Activity Forums Adobe After Effects Expressions Penner easing expressions with layer slide
  • Penner easing expressions with layer slide
    Posted by Olly Starkey on December 5, 2019 at 12:13 pm
    Hi all
    I’d like to find a way to slide a layer into position based on it’s in point. Currently I am using this expression.
    /* Legend:
    t: current time
    b: beginning value
    c: change In value
    d: duration
    function easeInOutExpo (t, b, c, d) {
    t /= d/2;
    if (t < 1) return c/2 * Math.pow( 2, 10 * (t – 1) ) + b;
    t–;
    return c/2 * ( -Math.pow( 2, -10 * t) + 2 ) + b;
    var xstartVal = 500;
    var ystartVal = 500
    var xendVal = 500;
    var yendVal = 800;
    var startDur = 0;
    var endDur = 1.8;
    t = time – startDur;
    d = endDur – startDur;
    y = easeInOutExpo (t,ystartVal, yendVal – ystartVal, d);
    x = easeInOutExpo (t,xstartVal, xendVal – xstartVal, d);
    [x,y];
    I’d like to be able to alter the ease velocity and looking a Robert Penner’s site I have tried to insert the easeOutQuint function but it failed spectacularly.
    This was Penner’s easeOutQuint expression
    public static float easeInOut (float t,float b , float c, float d) {
    if ((t/=d/2) < 1) return c/2*t*t*t*t*t + b;
    return c/2*((t-=2)*t*t*t*t + 2) + b;
    But it would be useful to be able to use any of his expressions.
    Is there an easy way to do it?
    Yoan Boisjoli replied 1 year, 4 months ago 5 Members · 11 Replies
  • 11 Replies
  • Dan Ebberts
    December 5, 2019 at 8:00 pm
    I think this works:
    function easeInOut (t,b,c,d) {
    if (t <= 0) return b;
    if (t >= d) return b + c;
    var ystartVal = 500
    var xendVal = 500;
    var yendVal = 800;
    var startDur = 0;
    var endDur = 1.8;
    t = time - startDur;
    d = endDur - startDur;
    y = easeInOut (t,ystartVal, yendVal - ystartVal, d);
    x = easeInOut (t,xstartVal, xendVal - xstartVal, d);
    [x,y];
    Dan
  • Olly Starkey
    December 9, 2019 at 10:18 am
    That works a treat, thanks so much Dan
  • Olly Starkey
    December 9, 2019 at 11:15 am
    Hey Dan
    Just playing around with this one, is there a way to start the animation based on the layers inPoint?
    Currently it starts animating at frame 0
  • Dan Ebberts
    December 9, 2019 at 5:05 pm
    I haven’t tested it, but I think all you’d have to do is change this:
    to this:
    t = time – (startDur + inPoint);
    Dan
  • Olly Starkey
    December 9, 2019 at 5:08 pm
    Hey Dan
    That works perfectly. Thanks so much.
    Olly
  • Andrew Sherman
    March 6, 2021 at 8:23 pm
    Dan, I’m a long-time beneficiary of your wisdom on these forums, so just wanted to say thank you, and I’m also a user of some of your paid scripts on aescripts.
    I’m trying to get this expression to work but I’m getting a syntax error (I think it’s the t = time line). Do you know how this might be resolved? I’m using latest AE CC.
    I also wanted to know how I might use a different easing, like one of the other Penner easings (expo or bounce etc). Do I just change the calculation in the function with the relevant math?
    // Penner easeInOutExpo
    var ystartVal = 500;
    var xendVal = 500;
    var yendVal = 800;
    var startDur = 0;
    var endDur = 1.8;
    y = easeInOut (t,ystartVal, yendVal – ystartVal, d);
    x = easeInOut (t,xstartVal, xendVal – xstartVal, d);
    [x,y];
  • Dan Ebberts
    March 6, 2021 at 9:44 pm
    Andrew,
    When code gets pasted into this forum, the minus signs can get converted to some other character, which breaks the expression. Try this version:
    var xendVal = 500;
    var yendVal = 800;
    var startDur = 0;
    var endDur = 1.8;
    t = time - (startDur + inPoint);
    [x,y];
    If you want a different ease, just change the code in the function (and the two references to the function if you change the name of the function).
  • Andrew Sherman
    March 8, 2021 at 1:51 pm
    Fantastic, thank you so much Dan
  • Ronan De lacy
    May 20, 2021 at 2:16 pm
    Hi Dan,
    Thanks for your explanations here. It’s starting to make things a little clear when trying ut use Penner easing in expressions. One question, however.
    I have it working with easeInOutExpo, but when I switch out the function to another Penner ease, either the scale of the object increases 100x(ish) or the animation loops.
    Any idea where I’m going wrong?
    Here’s my expression as it stands, working with easeInOutExpo.
    t /= d/2;
    if (t < 1) return c/2 * Math.pow( 2, 10 * (t - 1) ) + b;
    t--;
    Out=thisComp.layer("Controls").effect("Resolve By")("Slider"); //When should the animatiob be complete
    Dur=thisComp.layer("Controls").effect("End Resolve Duration")("Slider"); //How long should the animtion be
    x1 = 0;
    x2 = 24;
    t = time- Out+Dur;
    d = Dur;
    x=transform.scale[0]+easeInOutExpo(t,x1, x2 - x1, d);
    y=transform.scale[1]+easeInOutExpo(t,x1, x2 - x1, d);
    [x,y]
    And this one, for example, just loops continuously
    function easeInOutSine (t, b, c, d) {
    return -c / 2 * (Math.cos(Math.PI * t / d) - 1) + b;
    Out=thisComp.layer("Controls").effect("Resolve By")("Slider");//When should the animatiob be complete
    Dur=thisComp.layer("Controls").effect("End Resolve Duration")("Slider");//How long should the animtion be
    x1 = 0;
    x2 = 24;
    t = time- Out+Dur;
    d = Dur;
    x=transform.scale[0]+easeInOutSine(t,x1, x2 - x1, d);
    y=transform.scale[1]+easeInOutSine(t,x1, x2 - x1, d);
    [x,y]
  • Yoan Boisjoli
    April 4, 2025 at 12:41 am
    Hey all,
    I came across this thread while digging into Penner easing issues in AE a while back, and it brought me back. I hit a lot of the same walls, especially trying to get easing like easeInOutExpo or easeOutQuint to behave cleanly with time offsets and user controls in MOGRTs.
    I was so fed up that I built a tool to solve it. It lets you apply Penner easings to any property in After Effects, without using keyframes. It auto-detects the property, adds a control layer, and uses expressions under the hood so everything stays editable.
    If you’re still dealing with these types of easing headaches, this might help:
    https://aescripts.com/keyless/
    Just launched it recently and would love any feedback from folks who’ve already been down this rabbit hole.
