Activity › Forums › Adobe Premiere Pro › PC Restarts itself when burning to DVD from Adobe premeire pro 1.5 timeline?
Posted by Deleted User on May 1, 2005 at 1:20 pmI have been trying to burn a 50 min project from my timeline. I am using Adobe premeire pro 1.5. Half way through the machine just restarts itself on startup it then reports the system has recovered from an serious error?
Has anyone else had problems like these? I am running Service pack 2 so i think that is what is causing the problems?
As I just have XP PRO with Adobe Video Collection pro 1.5 with the latest updates for Encore etc. So not firewalls antivirus etc just a clean machine standalone not online.
I look forward to hearing from anyone you may of had a similar problem or know a workaround?
LEO 🙂
Keither5280 replied 21 years, 3 months ago 5 Members · 11 Replies -
Steven L. gotz
May 1, 2005 at 5:08 pmPerhaps a heat issue? Rendering and exporting take up as much CPU cycles as they can get. So perhaps it is overheating?
Unplug and open the case and check for dust. Clean everything out and try again.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Deleted User
May 1, 2005 at 7:14 pmHello Steven,
I have checked does not seem to be a over heating issue as seems quite cool in the rack case. I also checked for dust and reseated the cards.
Maybe as it’s a very long clip of 50mins 7mb 2 pass dv pal 4-3 I am running on a Asus P4R800 with 2x512mb ddr400 ram, Intel Pentium Multithreading 3.0ghz.
So could be a over heat issue?
-Leo 🙂
Steven L. gotz
May 1, 2005 at 9:37 pmThat or some odd memory problem. Maybe someone else has some ideas?
Steven
Deleted User
May 1, 2005 at 10:00 pmHello Steven,
It could be a bad memory issue or the clip is long as it’s 50 mins. As thats the longest clip I have needed to turn into a mpeg or DVD.
Also seems the transcoding from premeire Pro into a MPEG and once in
Encore took hours.Can’t see why it is so slow?
I wonder if there is a memory test software to maybe test ram?
Leo
Aanarav Sareen
May 1, 2005 at 10:06 pmLeo,
Download an ISO copy of MemTest and then run the diagnostics on start up. If there is even one error, you should be concerned:
Deleted User
May 1, 2005 at 10:14 pmHello,
Thanks for the link what do I download??
This one; Download – Pre-Compiled Bootable ISO (.zip)
Aanarav Sareen
May 1, 2005 at 10:59 pm[Leo Baker] “This one; Download – Pre-Compiled Bootable ISO (.zip)”
Yes. Download that and burn it onto a CD
Seawild
May 2, 2005 at 1:08 amYo Leo,
I just tried to burn a 20min video to DVD in Premiere using “Export to DVD” It looked simple enough… But I just not get to work. I just went to Encore to do it, a long wait in Encore for 50min of video seems resonable. It took a solid hour for me to burn 20min to DVD. Again no menus, no nothing, just play on insertion.
Oh well…
Deleted User
May 2, 2005 at 1:24 amHello,
Yes it seems an awfully long time to burn projects to DVD or MPEG 2 as mostly I have been going to tape but now doing DVD’s of finished projects.
I wonder if there is any way to speed up this process as liteally took me over 3hrs to Encode into low quality PAL 4-3, 1 pass process from Adobe premiere Pro to MPEG2 for DVD from the Adobe Media Encoder.
Maybe so one may know the best motherboard, memroy etc or if there is hardware acceleration available?
Leo
Deleted User
May 2, 2005 at 1:26 amI think, maybe the PC is overheating as over 3 hrs etc could be making the PC overheat if it’s rendering to MPEG2. I might have to look into cooling I am going to do the memory test later as well to see if I find any bad areas?
Leo 🙂
