Activity › Forums › Apple Final Cut Pro Legacy › PAL progressive project has interlaced dissolves??
Jeremy Garchow replied 17 years, 9 months ago 4 Members · 20 Replies
Jeremy Garchow
January 10, 2008 at 4:50 pmSteve is working on getting some footage over here. haven’t been able to take a look yet.
Jeremy
Jeremy Garchow
January 18, 2008 at 8:42 pmSorry guys. I finally got a chance to take a look at the footage, and I don’t see what you are seeing. Everything looks identical no matter how it’s set up.
Jeremy
Steve Voyk
January 19, 2008 at 4:13 amHi Jeremy,
Are you using a PAL project?
Are you viewing it on a progressive monitor or LCD?What we’re saying is that since it’s progressive, the dissolves and fade up from black should be progressive which they are not right now. Actually, try adding a video effect where the image moves across the screen and look whether it is showing interlaced or progressive on your MAC monitor (jaggies on edges of the moving image if interlaced).
Cheers,
Steve -
Jeremy Garchow
January 23, 2008 at 3:45 amPAL project, interlace monitor (Multi-format CRT)
[steve voyk] “Actually, try adding a video effect where the image moves across the screen and look whether it is showing interlaced or progressive on your MAC monitor (jaggies on edges of the moving image if interlaced). “
I don’t ever trust the mac monitor, I always look at a CRT. The canvas is not a very accurate measure of the signal. I will gladly take another look tomorrow though. I know that if I turn on field rendering, it will render interlace, if I turn off field rendering, it should render progressive and keep the resolution. In theory anyway. I will look in the AM, CST.
Jeremy
Geoff Walton
November 20, 2008 at 5:16 pmHowdy Steve,
Did you ever sort out your PAL timeline effects problem? I’m having exactly the same problems in the project I’m working on as you’ve described. I have pretty much determined that FCP effects are biased towards 23.98 or 29.97 timelines, and seem to be read as such by clips that are 25 fps.
I work on a fairly new 2 X 2.8 GHz Quad-Core Intel Xeon Mac with 16 GB of 800 MHz DDR2 FB-DIMM ram, and I have a HUGE systems 1.8 TB RAID that is pretty much rock-solid. I have FCP version 6.0.3, and I output to both PAL and NTSC Digi-Beta decks.
My work around is to copy the clips on either side of the transition in the finder (I use a MAC) and put them in their own folder. Then I batch conform them to 23.98 in Cinema Tools, import them into a 23.98 timeline in FCP that’s sized to PAL sD (720X576). Next I build my transition, render it, export the frames as an FCP Movie with the transition or fade in them (with a couple extra frames on either side for handles), then re batch conform the finished fixed clip back to 25 fps in Cinema Tools, and finally cut it back into my PAL timeline. There may be a tiny amount of quality loss but as I’m working in Uncompressed 10-bit it’s negligible, especially compared with the broadcast reject levels of ringing and interlace errors I get it I don’t use this work around. Also, I’m working on an animated series so I have a little wiggle room to cheat the frame difference I get using this method, but it’s incredibly time consuming. There’s lots of transitions in this series – so this is turning into a real nightmare!
The other thing I’ve noticed is that the problem has been somewhat intermittent! Some of my timelines seem to behave fine, and others do not! I’m using exactly the same settings in each timeline I work in – which are PAL 720X576,Aspect ratio is Anamorphic, CCIR 601/DV PAL (5:4), Pixel Aspect Ratio is PAL – CCIR 601 (720X576), Field dominance is Upper (Odd), Frame rate is 25 fps, and the compression is Uncompressed 10-bit.
If you or anyone else has a more elegant workaround, or any information on updates from FCP, or can direct me to a third party effects plug-in set designed specifically for FCP PAL timelines, I’d be much obliged!
Thanks for your time,
Geoff -
Jeremy Garchow
November 20, 2008 at 6:13 pmGeoff,
You say you are working in PAL and need progressive rendering, but yet your timeline is set to Upper FIeld First?
The first thing you need to do is set your timeline to a field dom of None. That will solve the interlaced renders. The next thing you need to do is select all in your timeline, then right click on any clip (or control click) and choose item properties > format and then find the row that says field dominance. You can then change the field dom of all your current clips that are on the timeline from Upper to None. You then need to go in to your bins in the browser and change the field dom of all your clips from Upper to None (this part you can do by selecting multiple clips, you have to do them one by one in the timeline). That way, any time you add a new clip to your timeline, you don’t need to go through this mess again.
Make sense?
Jeremy
Geoff Walton
November 20, 2008 at 7:14 pmHi Jeremy,
Wow, thanks for responding so quickly! Um yeah, that works – I tried changing the field dominance in Sequence Settings to None earlier, and it fixed the flickering transitions/fades, but I experienced the same jaggy artifacting of my clips that the other person described. So, I changed the clip setting’s field dominance to None as well – still artifacting – I didn’t realize that on my machine at least, I’d have to wait a moment for FCP to update, so this time I waited and voila, presto fixo. Also, it seems some clips like to have the transition removed, get rendered as None, and then have the transition re-applied – believe me, no big deal compared with my workaround.
Mucho Thanko!
Two more questions for you related to this change:
1) Are there any issues outputting this new sequence to PAL D-Beta? I thought PAL and Upper Field Dominance went together like peanut butter and jelly – there’s probably some kind of military/dominatrix pun in there somewhere, but I’ll leave well enough alone.
2)Are there any negative consequences to just going hog-wild and deleting my clips from the browser? (Consequences other than potential organizational head-aches) Actually, now that I write the word head-aches out, I’ll probably just change ’em to None in the browser…
Still, I am curious.1000 thanks!
Geoff
Jeremy Garchow
November 20, 2008 at 8:28 pm[Geoff Walton] “1) Are there any issues outputting this new sequence to PAL D-Beta?”
No. Your sequence will still be output in an interlaced transmission. Technically, you are outputting psf which is progressive material in an interlaced stream. Really, you don’t have to worry about it.
[Geoff Walton] “2)Are there any negative consequences to just going hog-wild and deleting my clips from the browser? (Consequences other than potential organizational head-aches) Actually, now that I write the word head-aches out, I’ll probably just change ’em to None in the browser… “
Why would you want to do this? Just set them to ‘None’ and be done with it, no?
Geoff Walton
November 20, 2008 at 8:50 pmYou’re absolutely right – it’s just a whole load of clips in 50 – 60 bins and the lazy part of me was trying to get out of doing some donkey work.
Thanks again for the sage advice and the timely response.
Geoff
Jeremy Garchow
November 20, 2008 at 9:18 pmThe stuff that’s in the bins you shoudl be able to change more than one at a time.
Select all the clips, then right click in the Field Dominance column and choose ‘none’.
Make more sense?
