Activity Forums Apple Final Cut Pro Legacy P2/DV … KG Core plug in …
  • Stuart Mcalister
    February 11, 2010 at 5:36 pm
    Thanks Shane. Will send overnight.
  • Stuart Mcalister
    February 12, 2010 at 6:19 am
    Shane,
    Herewith the top section of the report. I’m not sure I should post the whole report it here as it is enormous,
    Stuart
    Process: Final Cut Pro [148]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 6.0.6 (6.0.6)
    Build Info: FCPApp-905291121~12
    Code Type: X86 (Native)
    Parent Process: launchd [93]
    Date/Time: 2010-02-12 07:16:43.349 +0100
    OS Version: Mac OS X 10.6.2 (10C2234)
    Report Version: 6
    Interval Since Last Report: 138974 sec
    Crashes Since Last Report: 27
    Per-App Interval Since Last Report: 73667 sec
    Per-App Crashes Since Last Report: 23
    Anonymous UUID: 9D6E4D3F-4D6D-4934-985D-C46833FCB7B5
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    0 QuickTimeH264.scalar 0x163202b1 JVTCompEncodeFrame + 36944
    1 QuickTimeH264.scalar 0x16698f49 JVTLibDecoDispose + 322747
    2 QuickTimeH264.scalar 0x16624cd2 JVTCompEncodeFrame + 3201649
  • Shane Ross
    February 12, 2010 at 6:32 am
    Good enough. Got any h.264 media in this cut?
    Suspected Cause:
    This crash was likely caused by MPEG media (or MPEG-derived media such as XDCAM, HDV or H.264) in the timeline. This is one of many reasons why MPEG media is not recommended for editing.
    Suggested Actions:
    * Transcode any HDV, MPEG-2, XDCAM or other long-GOP media into an editing-friendly format such as ProRes or Apple Intermediate Codec (AIC).
    Relevant Line:
    Shane
  • Stuart Mcalister
    February 12, 2010 at 6:55 am
    Shane,
    COW is the best unofficial ‘customer support’ going …! Thanks!
    I have a timeline with the following footage:
    3 x camera rolls (P2)
    3 x Chroma Key backgrounds (.mov)
    Assorted GFX .pngs
    Using Boris FX Chroma Key Studio
    I downloaded the driver file linked from your ‘P2 to FCP’ tutorial but the first time I loaded it, the system said that it hadn’t installed correctly. I rebooted the machine and the second time there were no issues.
    Also, I downloaded the ‘preference manager’ and have deleted my prefs, yet still FCP crashed.
    On the 16H Mac Pro, the RAID drive is the scratch drive so I will now empty that and try again. I completed the edit on an iMac last night.
    Again, many thanks.
    Stuart
  • Stuart Mcalister
    February 12, 2010 at 8:57 am
    Going back over Shane’s tutorial, here’s something odd:
    – copy all files (Contents and lastclip.txt) onto separate drive
    – open FCP and make bin/logging bin (named as same)
    – edit > import > Panasonic P2
    This is where the sequence breaks as my ‘ edit > import > ‘ does not contain a Panasonic P2 option. However, I can import the files using ‘edit > log and transfer‘ as I just point it towards the folder on my desktop.
    Is this telling me that FCP doesn’t have the right driver to support P2?
    I have a AG-HPG20 reader/recorder. One card was recorded in the machine using the SDI route and has 2 tracks of audio, whereas the other card was recorded in a camera, has 4 tracks of audio and was labeled ‘spanned reel‘.
    Using ‘log and transfer ‘ the footage plays well enough in the timeline but a pro’s eye scanning over the above info should pick out any obvious problems … and hopefully, the last?
    Stuart
  • Shane Ross
    February 12, 2010 at 9:08 am
    YOu might be looking at my ORIGINAL P2 workflow tutorial, that I did when the option first came out. That is only for FCP 5.0 and 5.1. My updated tutorial works with FCP 6 and partially with 7. 7 has new features with naming…
    Anyway, here is tutorial for FCP 6.
    P2 Workflow with FCP 6
    Shane
  • Stuart Mcalister
    February 12, 2010 at 9:13 am
    Again, thank you Shane …
Page 2 of 2
