Activity Forums Panasonic Cameras P2CMS for Power Mac?
  • Jeremy Garchow
    June 23, 2008 at 6:58 pm
    [Shane Ross] ” Many people can’t work without that txt file. YOU might not have issues.”
    Very true. So far so good, though.
    [Shane Ross] “And it is always good to have verification of copying, so that is why I like P2 Log and HD Log.”
    CMS verifies. It’s called ‘Do Compare’ in the export options.
  • Niklas Wikman
    June 24, 2008 at 8:32 am
    For me using FCP – how should I use P2 Log? Does P2 Log copy the P2 files onto a disk I have choosen? (obviously, since it does verify the copy).
    Now I don’t have anything but a folder with P2 content (copied by using Finder). Can I use P2 Log demo on that footage for a try-out?
    Niklas
  • Jeremy Garchow
    June 24, 2008 at 2:52 pm
    [Niklas Wikman] “Does P2 Log copy the P2 files onto a disk I have choosen? “
    Yes. Then you can also log the footage and export an XML to FCP. The footage will come in logged (with your names) and wrapped in Quicktimes.
    [Niklas Wikman] “Can I use P2 Log demo on that footage for a try-out? “
    Only 10 seconds of footage or something like that. You will see when you download it. You will get a sense of what it does.
    Jeremy
  • Thomas Scheffer
    June 25, 2008 at 5:35 pm
    i ve bought hdlog and the software didnt work with p2stores and multiple clips.
    regards
    best regards
    thomas
  • Brian Wiebe
    June 25, 2008 at 5:40 pm
    I could be mistaken, but I was unable to offload and verify using P2log Pro–I upgraded to the Bronze version of HD log, and it works great.
    Also, the people at imagine software were very helpful.
  • Jeremy Garchow
    June 25, 2008 at 5:47 pm
    [Brian Wiebe] “I could be mistaken, but I was unable to offload and verify using P2log Pro–I upgraded to the Bronze version of HD log, and it works great. “
    You’re right about that and not mistaken.
  • Thomas Scheffer
    June 25, 2008 at 6:14 pm
    did you tried to offload from p2store?
    best regards
    thomas
  • Jeremy Garchow
    [thomas scheffer] “i ve bought hdlog and the software didnt work with p2stores and multiple clips. “
    It advertises that it works with p2 store, but what do you mean by multiple clips?
  • Thomas Scheffer
    June 25, 2008 at 6:20 pm
    multiple NO NAME partitions. i only wanted to warn somehow. with the demo, you cannot check
    this issue, because its limited to one clip.
    best regards
    thomas
  • Jeremy Garchow
    June 25, 2008 at 10:45 pm
    [thomas scheffer] “multiple NO NAME partitions. i only wanted to warn somehow. with the demo, you cannot check
    this issue, because its limited to one clip.”
    Did you contact Imagine Products about this? Their website is very misleading if this is true.
    https://www.imagineproducts.com/hdlog.htm then click on ‘Offload P2’.
Page 2 of 3
