Activity › Forums › Panasonic Cameras › P2 transfer to Mac
  • Alex Petrovitch
    April 3, 2010 at 12:15 am
    Great –
    let me ask you this.
    I am shooting so that it’s 1080, 24fps.
    The codec when I bring in the file into FCP 7 is 1280×1080
    Editing timebase 23.98
    QT: DVCPRO HD 1080p30 (don’t know why it defaults to 30- should I change it to 24?)
    When you ingest your data using SHOtPUT which I assume to be the same
    as P2CMS, you are ingesting the CONTENTS and LASTTEXT right?
    How do you get the footage to be readable in FCP7?
    The only way that I can get footage into FCP7 is to
    log and transfer inside of FCP7, not the CONTENTS/LASTTEXT.
    I’m told that CONTENTS/LASTTEXT is the RAW footage right?
    Anything that is a file brought through FCP7 is processed-
    Do you need them both? That’s TWO file transfers before
    you clear the P2 card? Takes a long time no?
    And should I only BACKUP the CONTENTS/LASTTEXT file?
    not the FCP7 processed?
  • Gerret Warner
    April 3, 2010 at 2:25 pm
    [Alex Petrovitch] “Great –
    Hmm. I’m not sure about that one. Is it possible you haven’t set your preferences as you want them?
    Shotput Pro is not P2CMS. It’s available for purchase online, and is great at offloading P2 cards to multiple drives at the time. All the shots you choose to log and transfer will show up in FCP’s browser. The CONTENTS/LASTTEXT files are part of MXF’s own metadata for managing the format.
    There’s no generational loss in Log and Transfer. The MXF files are your irreplaceable source: footage and information about it (metadata). It takes remarkably little time to Log & Transfer, much less than importing from tape. That’s one of many advantages to P2.
    not the FCP7 processed? “
    I typically keep all MXF files–labeled with a job prefix and 01, 02, etc–in 2 copies, each on a separate hard drive. These are the originals, like source tapes, and include everything you need should you ever want to re-log and transfer into the FCP project at some time in the future.
    Hope this helps.
  • Alex Petrovitch
    April 6, 2010 at 7:08 pm
    Question-
    So when you drag the info onto the timeline it sets the QT settings to DVCPRO HD 720p60.
    why “60”? aren’t you using 24 fps?
    Secondly,
    why can’t I drag and drop “CONTENTS” and “LASTCLIP” instead of using “shotput pro” or “P2CMS”.
    Thirdly,
    the footage I have shot on the HVX200 seems to have lines going across the screen everytime that a subject moves – is that because I shot in 1080i? Should I be using 720p?
    Fourthly,
    What’s the difference of importing/ingesting my footage via “CONTENTS” and “LASTCLIP” versus importing/ingesting my data when I’m already logged into FCP7, and I just get the data already re-wrapped into MOV files?
    If I import/ingest the “CONTENTS” and “LASTCLIP”, the files are in MXF format. What the heck is that?!
    Thank you for your information!
  • Gerret Warner
    April 6, 2010 at 7:44 pm
    [Alex Petrovitch] “Question-
    While shooting 24 fps video, unless you choose 720PN (native), you are shooting “24 over 60” as they say. When you shoot native 24 (23.98), you are recording only those 24 frames per second, not 30 fps.
    Secondly,
    You’ll have to ask someone else for that. Just the way it is.
    Thirdly,
    I’m not sure what that might be. My 1st thought was strobing, which is increased in pans when you go from 30 fps to 24. You can adjust the shutter. And you can minimize the problem with an object in the foreground.
    Fourthly,
    I’m sure others can give you a more technical answer than I, but in short, MXF is a container which includes your footage as well as metadata about it. As far as I know “LASTCLIP” is a file that connects footage that spans two cards. I think there is 3rd party software that allows editing directly from MXF files in FCP. Otherwise I don’t know of any alternative to simply Log and Transfer MXF into FCP.
    Thank you for your information!”
  • Alex Petrovitch
    April 7, 2010 at 4:29 pm
    Thanks again for your info.
    I finally understand it.
    Last question.
    I’m using P2CMS to tranfer the footage.
    When I look at the HD, it looks like it’s the “CONTENTS” folder.
    I don’t see LASTCLIP anywhere. Is that okay?
    When you do the “drag and drop” everyone says “GET THE CONTENTS AND LASTCLIP! DON’T FORGET LASTCLIP!!!”.
    By using SHOTPUT PRO, or P2CMS, is the LASTCLIP already included some how?
    thanks,
    alex
  • Gerret Warner
    April 7, 2010 at 9:31 pm
    [Alex Petrovitch] “Thanks again for your info.
    Last question.
    When you write “HD” are you referring to your hard drive? Once I’ve copied my P2 cards to folders on my hard drive, each one contains both a CONTENTS and LASTCLIP.TXT file.
    To my knowledge, neither ShotPut Pro nor P2CMS use drag and drop. You “ingest” or “import” (I can’t remember which), and the CONTENTS and LASTCLIP files aren’t visible after the import, only your footage and data about them.
    It takes awhile to get used to the idea of shooting to cards and then double backing up and –worst of all–wiping a card clean after all the work you did in getting the shots. But once you work out a work flow that’s comfortable for you, it’s a great system. Now that i shoot on 64 GB cards, I can shoot all day in 720PN/24 without dumping a card… and that’s life-changing.
    Good luck with it all, Gerret
    thanks,
    alex”
Page 2 of 2
