Activity › Forums › Panasonic Cameras › P2 Transfer Question
Jeremy Garchow
April 17, 2009 at 5:47 pmLooks like HVX footage to me, not a low res jpeg. You will have a bit of trouble keying the hair
Jeremy
Jeremy Garchow
April 17, 2009 at 5:58 pm -
Chris Bierlein
April 17, 2009 at 6:05 pmTry keying it. That’s when the problems arise. Looks way worse than other HVX keys I’ve done.
D. scott Dobbie
April 17, 2009 at 6:19 pmThat looks clean, Jeremy.
Chris, have you worked with that post house previously? Can you upload a shot showing the jaggies?
Chris Bierlein
April 17, 2009 at 6:50 pmOn the road all day away from computer. Will check out and respond tonight!!! Anxious to see your results.
Chris Bierlein
April 18, 2009 at 7:39 amHey everyone, Thanks for the help and responses! Jeremy, your key looks great. Did you have jaggies at first, and then soften the edges? Apparently the post house has come up with a fix, but I don’t know what it is yet. Check out the Jaggies. I did this in FCP, but the post guys were using AE and had the same result.
Softening the edges helps alot, but I’m know it shouldn’t look so “jaggy” in the first place.
Chris B
Jeremy Garchow
April 18, 2009 at 4:24 pm[Chris Bierlein] “Did you have jaggies at first, and then soften the edges?”
No, not jaggies like that. I applied a tiny amount of blur, but really not that much.
