Activity › Forums › Apple Final Cut Pro Legacy › P2 Log and Transfer Problem
Shane Ross
October 6, 2009 at 1:37 amIt isn’t absolutly necessary. I believe you can import without it.
Shane
Read my blog, Little Frog in High Def -
Lena Franford
July 1, 2010 at 5:40 pmI’m having trouble editing my movs. I followed this tutorial up until the point of logging and transferring https://www.youtube.com/watch?v=1fqTxX1zamo when I get to that point i get this message: “2010-06-23 Shawn Pierce ” contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.” . Any chance you could help?
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Lena Franford
July 1, 2010 at 7:05 pmTwo folders:One, DCIM>100EOS7D>MOV and THM files. Two, MISC folder which is empty.
Shane Ross
July 1, 2010 at 7:14 pmLena. That is the directory structure of something shot with the Canon 7D. You need to install the Canon EOS plugin to import that footage via Log And Transfer.
Shane
Jeremy Garchow
July 1, 2010 at 7:21 pmThose aren’t P2 files, but rather Canon HDSLR files. You have to download the free log and transfer plug from Canon and install it.
https://www.usa.canon.com/dlc/controller?act=GetArticleAct&articleID=3249
Lena Franford
July 1, 2010 at 7:37 pmwhich Canon EOS plugin? there are a few..is it utility version 2.7.1?
Jeremy Garchow
July 1, 2010 at 7:46 pmIt’s right there in the link I sent. you need the one for “final Cut Pro”.
Lena Franford
July 1, 2010 at 8:49 pmThanks you guys. I think it works… I have to run to a shoot, but will be editing in a few hours.
Cheers!
