Activity › Forums › Apple Final Cut Pro Legacy › P2 codec problem
  • Douglas Darlington
    May 15, 2009 at 8:48 pm
    Does this decoder also work for viewing the .mov in Adobe Premier? I shot HD P2 footage that my clients wants to edit in Premier. If not is there a plug-in/codec that will make DVCPro HD files viewable in other editing software such as Premier?
  • Dennis Radeke
    May 19, 2009 at 12:20 pm
    Premiere Pro supports native p2 .mxf files in version CS3 and above. If the file has been captured as DV100 QT, Premiere Pro can read that as well.
  • Bjoern Adamski
    May 23, 2009 at 9:41 am
    Shane,
    basically it’s not FCP that installs Apple’s pro codecs, it’s Compressor. Any installation of Compressor will do it, it’s part of FC Studio, FC Server and Logic Pro.
    Product Manager
    MXF4mac
    https://mxf4mac.com
  • Robert Lee
    December 28, 2009 at 9:42 pm
    i am having the same problem as the prior writer. I downloaded the demo version of DVC Pro HD component and now i have watermarks.. i then Installed a full version of CS3 Adobe Premiere to do the editing of my footage.. then uninstalled all the demo files like the read me file said to do.. it shows that i have no files remaining to uninstall.. Restarted the computer and i still have watermarks.. please help.. thanks
  • Dennis Radeke
    December 29, 2009 at 1:10 pm
    There is a clean script you can run in case something in the installer didn’t work properly. Also, if you’re using CS3, make sure you’re using at least Premiere Pro CS3.1 which supports P2 (3.2 was the last version)
Page 2 of 2
