Activity › Forums › Panasonic Cameras › P-2 XML Files messed up
  • Kevin Christopher
    April 29, 2010 at 4:36 am
    Ok I must be an Idiot, or really sleepy. I can not make this thing do anything. How do I make it work?
    Kevin
  • Andreas Kiel
    April 29, 2010 at 11:27 am
    Hi Kevin,
    As said, I uploaded the old ‘quick hack’. It will work on 10.4.x and on 10.5.x. NOT on 10.6.x
    Here a short ‘how to…’
    After you read CAREFULLY the the start up message and agreed, you’ll see an empty window like below.
    Then use the ‘Load P2’ button and select one or more cards.
    The window may look like below.
    The XML TCs will be converted to frames.
    Then press the ‘Process and Save P2’. The application will search for XML clips which are continuous – it doesn’t look into the MXF structure!
    You will get a screen like below.
    That’s it.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Kevin Christopher
    April 29, 2010 at 12:59 pm
    Using OS X 10.5.8. Thats what I am doing, but nothing opens in the window. perhaps I could zip the xmls up and send them to you.
    Kevin
  • Andreas Kiel
    April 29, 2010 at 2:28 pm
    Kevin,
    You can do that – maybe some more stuff is broken.
    Andreas
    Spherico
  • Andreas Kiel
    April 30, 2010 at 9:06 am
    Just to keep the info on this thread up to date.
    I got the XMLs from Kevin, they are really messed.
    So a good idea for anybody who thinks about using HDLog would be to duplicate the CLIP folder on your card folder before using HDLog. This won’t destroy the card structure.
    Andreas
    Spherico
Page 2 of 2
